Matte or Shiny?
Matte or Shiny?
Take a look at my rubber A-pillar window seal. After 10 years it is starting to deteriorate but, which way? I assume it had a harder shiny finish that broke down, but is the inverse true? I would like to know before I restore, it certainly does not respond to 303 or any trim restorer.
Matte or Shiny; which is OG?
Thanks for the input. I'm still torn - it does appear the shinier rubber is the original finish, and over time it has weathered naturally. This car has lived under a cover/garage all its life so I don't believe it is sun related, just deterioration of the rubber.
I should not be so petty...
997.2GTS (11-04-2021)
All of the rest of the trim on my car is in pristine condition.
I'm striving to locate them online, just to know what the price is. The same for me; all other trim is immaculate, only this piece has the delamination issue. They probably can be gently sanded and re-protected once they get bad enough.
I'll shut up and drive now, I think.
You should be able to clean that. Take a look at Nextzett rubber cleaning products. And you can also try to clean and preserve wit h 303 Aerospace Protectant. It may take some insisting, using a towel or foam applicator.
997.2GTS (11-05-2021)
or ???
From Nextzett:
Aktiv Autobalsam
and
Gummi Pflege Rubber Care Stick
Use Aktiv Autobalsam with a towel to clean the rubber trim. It will take some energy and several applications to fully clean it. That will be enough and going forward reapply it periodically. Or, once clean, coat it with Gummi Pfledge.
Aktiv Autobalsam
and
Ironman88 (11-06-2021)
From Nextzett:
Aktiv Autobalsam
and
Aktiv Autobalsam
and
I'll follow up with before / after photos.
Ironman, a 3 year old prevents me timely addressing these types of projects, so I would be keen to see your results, thanks in advance for posting!
ADias, thanks for the product insight, I appreciate it.
