Function First Engine Mounts just Installed...
Old Oct 18, 2021 | 03:48 PM
frybear's Avatar
frybear
Default Function First Engine Mounts just Installed...
Function First engine mounts are in. I should have taken before pics of the exhaust but they do seem higher to me than I recall, really tucked up there. So...WRT to other things I've heard, car doesn't start any differently and I can't really tell about throttle response, could be better, but can't say for sure. Definitely vibrates more on my butt, which I kinda like! And I have heard that they do break in after about a thousand miles. All in all I'm happy with them. Install took me an hour, most people say 20 minutes. I had a tough time at first getting the dang plug out of the airbox. And getting the airbox back in took a little bit of time wiggling it back in place. Be aware that on my car there are two rubber gaskets/plugs that sit in the body of the car where the airbox sits - one popped out and fell on the ground as I was unbolting the bottom bolt from under the car, so luckily I noticed it. It just pops back in the car but make sure you have those.
Old Oct 19, 2021 | 04:21 PM
aramosc's Avatar
aramosc
Thanks for sharing! The car looks great!
Do you (or anyone else) know what the life expectancy of semi solid mounts is versus the stock ones?
Old Oct 19, 2021 | 05:15 PM
David Berry's Avatar
David Berry
Try the Function First transmission mount insert. The Sport version
really adds to the race car feel. Takes away that comfy car feeling,
Old Oct 19, 2021 | 07:42 PM
bheit1's Avatar
bheit1
The vibration you're feeling often sets off the engine knock sensor. That retards timing and reduces power. This has been hashed over plenty on here - search for Jake Raby's video on semi solid mounts.
Old Oct 19, 2021 | 07:51 PM
frybear's Avatar
frybear
Then it’s good that the vibration is very minimal. Don’t really notice it much.
Old Oct 20, 2021 | 11:39 AM
AxelR's Avatar
AxelR
Regarding Jake’s findings:
I remember this as well. Is it true for all vehicles? Or is it true for the M96/97 engines?
i don’t recall the details and/or mention of the 997.2.
Old Oct 20, 2021 | 12:03 PM
Wayne Smith's Avatar
Wayne Smith
M96/97. I have not seen any data on the 9A1 motor.
