997.1 Power Issue After X-Pipe Install
Old Oct 12, 2021 | 11:07 AM
dubsiren's Avatar
dubsiren
Originally Posted by Petza914
I have the Fabspeed 200 cell X-pipe and none of these issues. Someone messed up something with the X-pipe install, probably related to the O2 sensors? Any CELs or codes? What are they?
The O2 sensors are color coded per side - blue on one side and grey on the other. The other thing I've seen people do is not disconnect them from the connection blocks at the rear of the engine compartment and jsut unscrew them with the connection end still connected and then rescrew them in - this is way too much twisting of the wires for them to survive, but people that don't know how easy they are to disconnect and reconnect do it the wrong way and damage them - they're not cheap!
no CEL codes. But my OBD Link software is only showing voltage on O2 sensor 2. O2 sensor 1 shows 0. This is even after replacement of the O2 sensors.
Old Oct 12, 2021 | 11:18 AM
Petza914's Avatar
Petza914
Go to the back of the car and in each corner are the connection blocks for the O2 sensors. You lift the locking clip and the plugs just lift out. For starters, make sure they're connected to the correct ports and on the correct sides. If I recall, it is obvious which one should go where and the grey wire sensors go on the grey plugs side and the blue wire sensors on the blue plugs side.
Old Oct 12, 2021 | 02:47 PM
dubsiren's Avatar
dubsiren
here is the reading from OBDLink at idle
Old Oct 14, 2021 | 04:30 PM
dubsiren's Avatar
dubsiren
Here are some scans from my car while at idle.
Car is still acting very strange. The hesitation is 100% reproducible. If I am driving at low speed, coasting, and blip the gas, it bottoms out and then downshifts. ALSO. If I do a 0-60 run, and step on the gas from 1st, the car hesitates, then wakes up and revs through the power band normally.
To recap:
997.1 S Tiptronic
GT3 Throttlebody
IPD Plenum
GIAC tune
No problems at all. Car was fast as ****.
THEN added Fabspeed X-pipe and new O2 sensors, and that’s when the trouble started. Shop says the O2 sensors are in correct order.
Old Oct 14, 2021 | 05:57 PM
Petza914's Avatar
Petza914
So the GT3 throttle body and ipd plenum were already installed prior to the X-pipe or done at the same time?
Your bank 1 and bank 2 long term fuel trim numbers look odd like you may have a vacuum leak, which is usually at the plenum when installed as it's tough to get the rubber ends on properly.
You have a smoke test machine?
Old Oct 14, 2021 | 06:39 PM
dubsiren's Avatar
dubsiren
I don’t think I need one….. back to the shop it goes….
Old Oct 14, 2021 | 07:09 PM
dubsiren's Avatar
dubsiren
the throttle body and plenum were installed together with the tune. The x-pipe was installed a few weeks later.
Old Oct 15, 2021 | 11:43 AM
Fabspeed Motorsport's Avatar
Fabspeed Motorsport
Basic Sponsor
Extremely unlikely that it would be related to the X-pipe, it wouldn't cause those codes. Typically only P430/420 for Cat inefficiency.
Regardless, I am more than happy to help you work through it. Shoot me an email so we can connect - Service@Fabspeed.com
Hamsa Naser
Hamsa@Fabspeed.com
P:215-618-9796
Old Oct 15, 2021 | 03:20 PM
dubsiren's Avatar
dubsiren
The only reason I point to the x-pipe is that the issue started IMMEDIATELY after the x-pipe was installed. Before the x-pipe, the car was running flawlessly. The only thing that changed were sensors and the x-pipe. The sensors have been completely replaced, a second time, still an issue.
Old Oct 15, 2021 | 03:58 PM
Fabspeed Motorsport
Basic Sponsor
I understand your frustrations completely, that is why I want to connect and see if our Engineers cant work to find a solution for you!
My reason for thinking it is unrelated to the X-pipe, and just a coincidence, is that the only portion of the X that has the potential to cause codes is the cats themselves. Which do not seem to be relevant to the codes you're showing. regardless all our products carry lifetime warranties, so you're more than welcome to send it in for testing as well!
Old Oct 15, 2021 | 04:19 PM
dubsiren's Avatar
dubsiren
the shop that installed it will check the car out next week.
Old Oct 15, 2021 | 05:14 PM
wndsnd's Avatar
wndsnd
To me it sounds like a vacuum leak on a intake plenum boot. Is it possible that when you did the IPD that a boot clamp might have been loose or sealed incorrectly and just cooincidently just lost vacuum at same time you did the X-Pipe?
Old Oct 22, 2021 | 08:25 PM
dubsiren's Avatar
dubsiren
I talked to the shop today. My car is staying over the weekend. They have tested, tested and tested, and it seems to be coming back to the Fabspeed x-pipe. Fabspeed wants them to pressure test the x-pipe. At this point, I am ready to throw the x-pipe in the river and put my old cats back on. The car was perfect before the x-pipe went on, and now it is 100% reproducible on the brink of stalling.
Old Oct 22, 2021 | 09:09 PM
cwheeler's Avatar
cwheeler
X-pipe ain't causing the issue n
Old Oct 22, 2021 | 09:13 PM
rtl5009's Avatar
rtl5009
This thread is hilarious
