Should I Repair Windshield Chip?
I have a 1 by 4mm chip in the front windshield of a 10 year old, very low mileage C2S that I may be trading in soon. I have read the generally favorable reviews of Safelite replacing windshields with OE glass. I have used them to replace windshields on my other cars and always been very satisfied. Do you think I should go ahead and similarly have the front windshield replaced with OE glass at Safelite and take a chance that it isn't done properly or just leave it as is expecting to trade the car in to the dealer? Assume the cost of the repair is not a significant factor.
The following 5 users liked this post by Jaws1:
8KaboveMSL (08-22-2021),
997.2GTS (04-05-2023),
bbinder (08-21-2021),
MrMoose (08-21-2021),
TerrestrialFlyte (08-21-2021)
If you call your insurance they'll generally cover chip repair. I had Safelite fill a chip going through USAA and I don't think I paid a dime. They even drove out and did it in the parking lot while I worked.
You should definitely get it taken care of. Small chips can crack and lead to needing a replacement. The process is much less invasive than a replacement. A repaired chip would have no negative impact on the value of your car where as a broken windshield definitely would! I believe all insurance companies with the exception.of AAA and State farm will wave your deductible and preform the repair at no cost when the replacement falls under you comprehensive deductible.
I had similar situation w/ chip. Did some research here and found some windshield replacement horror stories. Apparently there are some tricks to getting the job done right, OEM replacement is not the only concern. Convinced myself that if I ever need a full windshield replacement that I would do my research and find someone who knows what they are doing/have experience working on 997’s.
Went ahead and spent the $50 to get the chip filled. Paid for it out of pocket, not worth getting insurance involved.
carguy999 (09-04-2023)
I would repair. You can actually do it yourself. You can buy chip repair kits at the auto parts store. Very easy to do - anyone can do it in your own driveway. Very inexpensive as well. I’ve done my own windshield chip repair on all my cars for years now. Fix it and be done with it, and don’t worry about telling the dealer. Disclosure only applies to things a reasonable person could not see. A windshield is not something anyone would miss.
cbredesen (04-05-2023)
repair windshield crack kit
Considering you may be trading in your car soon, it makes sense to save costs while still ensuring a presentable appearance. Repairing the chip with a kit like the Crack Eraser Repair Upgrade Kit would be a practical choice. It will not only restore the windshield's functionality but also enhance its visual appeal.
You can find more information about the kit and make a purchase at https://crackeraser.com/products/cra...ir-upgrade-kit. I believe this option will provide a satisfactory result without the need for a full windshield replacement.
Considering your situation of having a small chip and your plan to trade in the car soon, I'd suggest opting for the OE glass replacement with Safelite. Since you've had positive experiences with them before, it's a reliable choice to ensure the windshield is properly replaced. However, if you're open to exploring alternatives, you might want to check out the windshield crack repair kit from Crack Eraser at crackeraser.com. It could potentially be a cost-effective and convenient option to repair the chip before trading in the car.
Hey there! It sounds like you've got a decision to make. If the cost isn't a significant concern, and you've had good experiences with Safelite, it might be worth considering the replacement for peace of mind. However, if you're leaning towards trading in the car soon, it could be more practical to leave it as is. Just to throw another option in the mix, you might also explore the possibility of a repair with a professional using a high-quality kit like those offered by Crack Eraser (check them out at crackeraser.com). It could be a middle-ground solution if you're unsure about replacement. 🪟🚗✨
