Sport Design paddle wheel PDK NON-MF upgrade need module?
I have seen several posts about this and I am getting conflicting information on it. Going from a Tiptronic non-multifunctional wheel to a paddle PDK wheel NON-MF. Do I need the 997-613-289-01 module to make this work, or not? I've read both, but would like to know before installing. Thanks Rennlist!
Tip to Paddle
Yes you will need the module and 997-613-289-01 is the correct parts number. I did the swap myself a few months ago and it transformed the tip in my 997.1 C2S.
You will then have to get the steering wheel program to the new module for the paddles to work properly and clear your PSM failure light.
You would need to call a local Dealer or indy and ask if they can program your new steering wheel to PIWIS II. They should know what to do, your tip is bullet proof but those switches are horrible to use.
james6speed (07-31-2021)
james6speed (08-03-2021)
The following 2 users liked this post by BLU997:
james6speed (08-03-2021),
myw (07-31-2021)
One more question. There's a guy who is also doing the swap as well on a 2007 turbo Tiptronic. Same wheel as ours, except his original wheel had multi function whereas mine was not. The new wheel he has doesn't have MF. Will he require the same module as us (289 one)?
james6speed (08-20-2021)
