2007 C2S Starting issue
Old May 24, 2021 | 07:54 AM
remec6304's Avatar
remec6304
Default 2007 C2S Starting issue
Hi there all,
Help needed, Short version of the issue.
If I do not start the car for a couple of days it starts great, turns over fine and start on the button revs to1500rpm then drops off once heat cycle is over(which may I add takes a while even in the Dubai heat)
If I start the car every morning to go to work it turns over fine but once started it does not give me that burst of revs on start, probably not over 1000rpm then sits there for quite some time on the heat cycle. If I start the car again within minutes of shutting off it starts great with revs bursting up to 1200-1500rpm with no heat cycle waiting time.
However if I leave the car for a few hours then start it turns over fine but revs are very low sometimes even stalling. if I try again immediately after this it starts ok but as above with low RPM. Idle does seem rough till really up to temp.
Anyone have any idea what is could be?
By the way my diagnostic shows not codes!
Thanks in advance for any help provided.
Old May 25, 2021 | 10:14 AM
Petza914's Avatar
Petza914
Could be the air temp sensor that's built into the MAF sensor or the coolant temp sensor. This control that start up prototcol, elevated revs and enrichment when cold and not when hot. If you have a Durametric see what those read dieing cold start and warm start and see if either is erratic and dumping around or reading what looks like an implausible value.
Could also be a vacuum leak that's effecting airflow but only causing an issue in certain circumstances.
Old May 25, 2021 | 08:15 PM
David Berry's Avatar
David Berry
MAF?
Old May 26, 2021 | 01:12 AM
remec6304's Avatar
remec6304
When I unplug the MAF it struggles/ run rough.
Old May 26, 2021 | 07:20 AM
David Berry
Clean or replace the MAF, unplugging it won’t help you.
Old May 26, 2021 | 07:23 AM
David Berry
Or try an “Italian tune up”. Drive it like you stole it. Run the revs up to 7,000 rpm. Clean it out.
Old May 26, 2021 | 08:35 AM
remec6304's Avatar
remec6304
99% of the time I drive like I stole it, that's what its built for haha.
I need to get it on a decent diagnostic to be honest, the one I have is not up to it.
