Mr12volt installed
Hi Just installed this into my 997.1 and works right after the bat, but have 2 issues not sure if this is normal.
1) phone calls come in on one side of car (passenger side channel) nothing can be heard on drivers side.
2) mic is placed in factory location...calls can hear my clearly then fazes out where i need to yell...then normal again. (any adjustments your recommend?)
thanks in advance.
thanks in advance.
I broke my mic that came with mr12volt (which worked good) and replaced it with Enfig-Por1. My wife says the mr12volt mic is better than Enfig.
I clipped the mr12volt mic to the left side of sun visor. Enfig mic is mounted in the upper steering column cover, looks clean but keeps getting complain from her on voice quality and noise.
I think mounting location is more important.
Yes. Iirc it does only come out of one side,.I can test next time I'm in the car.
Regarding placement, you cannot see it when it's tucked in the hole there and the sound quality, according to folks on the other end is good.
I never had a good location for the microphone. Most people complained of the sound.
It did just come out of the one side to the best of my recollection.
Someone found a better microphone and it got good reviews from here. Should be easily searched.
Thanks - ive been scanning through all of the forums to see and the only microphone being mentioned is the one from Enfig... ill keep searching.
