Airbag Coding - Foxwell NT520 ?
Old Apr 14, 2021 | 09:47 AM
platinum997's Avatar
platinum997
Default Airbag Coding - Foxwell NT520 ?
I know you can do some coding with the NT520. Has anyone successfully turned off the various airbag modules with it?
I am specifically looking to disable the below modules highlighted in yellow. This is a screenshot from a Durametric. I am trying to avoid buying/renting one again.
Old Apr 14, 2021 | 10:23 AM
Sylverlee's Avatar
Sylverlee
—__
Old Apr 14, 2021 | 10:30 AM
platinum997
Can you provide the process. I can try over lunch today and post the results.
Old Apr 14, 2021 | 10:55 AM
Sylverlee's Avatar
Sylverlee
—__
Old Apr 14, 2021 | 12:11 PM
platinum997
I got it.. Just needed to look harder. This is for aftermarket seats with no airbag and no heat. NOTE: I update the screenshot in the first post with the proper settings.
Programing / POSIP / Customer-Specific Settings
  • Driver Thorax Airbag = No
  • Passenger Thorax Airbag = No
  • AWS = No
  • Belt Buckle on Driver Side = No
  • Belt Bucket on Passenger Side = No
Programing / Vech.Electrical Sys / Customer-Specific Settings
  • Left Seat Heater = Not Installed
  • Right Seat Heater = Not Installed
Old Apr 14, 2021 | 12:52 PM
Sylverlee's Avatar
Sylverlee
—__
Sylverlee's Avatar
Sylverlee
—__
Old Apr 14, 2021 | 01:13 PM
platinum997
yes.. mine starting doing that when I disable the seat belt chime. So not associated with the above changes.
Maybe anything changed for airbag, belts causes that.. not sure.
Old Apr 15, 2021 | 02:31 PM
Petza914's Avatar
Petza914
Is this on a .1 or .2. Someday I may try to re-enable the seat heating of the heated seats I installed as I also have the switch panel to install, but the last time I tried it I was unsuccessful. Is the menu mentioned above the only place where seat heating has to be enabled / disabled?
Old Apr 15, 2021 | 05:06 PM
platinum997
This was for a .2
The codes went away for the seat warmer but am not sure if there is another location as well for a full disable/enable.
Old Sep 29, 2021 | 03:56 PM
415CPA's Avatar
415CPA
  • AWS = No
Thanks for posting this. Coding worked perfectly after I installed my Recaros.
