Transmission Oil for manual gear box
Hello Everyone -
I wanted to change the transmission oil of my 997.2 C4S and I was wondering if there is any difference (except the price), between those to oils:
- Mobil 1 Delvac 75W-90: https://www.suncoastparts.com/product/DELVAC.html
- Mobil 1 Mobilube PTX 75W-90: https://www.suncoastparts.com/product/00004320420L.html
Thanks!
Riccardo
Thanks!
Riccardo
tegraphile (04-12-2021)
There's only one choice - Mobillube PTX.
2009 C2S 170K miles
PTX is a GL-4.5 rated oil specifically formulated for transaxles. A transaxle is both a transmission and a differential using the same fluid. Delvac is not for transaxles but specifically for differentials, a GL-5 rating. Just read your manual, it tells you exactly what to use, and that is PTX GL 4.5, not Delvac.
Read more here: https://rennlist.com/forums/997-foru...-gear-oil.html
Peace
Bruce in Philly
Peace
Bruce in Philly
RiccardoB (04-12-2021)
Thanks everyone.
I will proceed to purchase 3L of PTX from suncoastsparts.
Should I buy the drain plug too?
https://www.suncoastparts.com/product/PK997MTPLUG.html
TIA
Riccardo
TIA
Riccardo
Thanks everyone.
TIA
Riccardo
TIA
Riccardo
Don't buy the drain plug or the sealing washer /aluminum gasket from them either. They will want about $20 for the Toyota aluminum washer, you need 2. Just use the same $0.50 washer that you use for engine drain plug, (18 mm x 24 mmx 1.5 mm thk. Also do use a 6 point socket on the drain and fill plugs. The heads on these are stupid thin and will take a lot of force to break them free. The cheapie lube pump (about $9 ) from local auto parts store will screw onto the bottles of the Porsche branded PTX and work fine for filling. Fiddling with the big under tray of the cars is the biggest part of the project.
Thanks everyone.
TIA
Riccardo
TIA
Riccardo
RiccardoB (04-13-2021)
