Function-First Engine Mounts - 997.2
Looking to get a feedback update from any of those who have gone with Function-First engine mounts. Any experiences with them on 997.2 would be of particular interest.
What benefits have you experienced?
Any concerns / problems / issues of any kind?
How would you compare after-install NVH with the previous mounts?
How did the install affect the position of your exhaust tips relative to their position with the old / replaced mounts?
Thanks.
Thanks.
The exhaust tips are a red herring IMHO. If you loosen the securing bolt you will find you can adjust them up or down an inch. You really need to level them relative to each other before you trust any measurements.
I believe one set of motor mounts I installed for a friend were F1. He likes them ... Standard comments apply regarding better shifting and less rear end flex with no appreciable increase in NVH. This was for a 2010 C4S MT with around 75K miles.
I opted for Rennline for two reasons ...
1. They included multiple inserts to show a myriad of hardnesses. With three hardnesses times two inserts per mount and the ability to mix or match you have six combinations.
2. The machining is beautiful IMHO.
Even with the full hardness I found no significant increase in NVH but I did see a major improvement on rear end stability. Especially the case on high speed sweepers with undulations. This was another 2010 C4S but with PDK and 136K miles.
Ironman88 (02-02-2021)
Just for clarity - the Rennline you're referring to is the one depicted below? Also - went with the red inserts?
For my use, I would probably consider the opposite end of the hardness spectrum (yellow)...
I recently installed the FF engine mounts, along with the Shift Right bushings and cable ends, review here — https://rennlist.com/forums/997-foru...nsmission.html.
Biggest change was the mounts got rid of the thumping between shifts. A bit more vibration at idle and changed the exhaust note in a positive way. I think it’s a great upgrade overall.
Those are the ones. I started with the hardest inserts figuring I could go softer more easily than harder (which would then require retreating to softer once/if I found NVH to be excessive). As it was, hardest was a good place. If your mounts are worn they may be allowing NVH as the motor may be bouncing. In other words, harder may result in smoother. But this isn't an easy algorithm to figure. All the more reason for adjustability. All the more reason to start hard. Of course YMMV.
Ironman88 (02-03-2021)
https://rennlist.com/forums/997-turb...ne-mounts.html
I put these in my 09 C2 about 4 months ago and am very pleased. You can see how the cavity has been really professionally filled providing much less flex.
I already had the FF Transmission mount installed, and while I was expecting some NVH increase, after several months I can say that it is absolutely minimal . To describe it differently, I have to listen quite deliberately to even notice it. Caveat - I also have the FVD Sport Exhaust so my car is quite a bit louder than stock.
The connection feels better on launches and quick direction changes. I would definitely recommend them.
Huge thumbs up for the FF Engine mounts.
I took a gamble on the RSS mounts first and installed them.
I don't understand how people say they felt little to no increase on NVH with them?
I found it very noticeable and in the end unbearable for a car I like to put miles on.
And it exposed some rattles that I didn't have before...
Swapped out to FF and performance was the same but ZERO increase in NVH.
Best of both worlds IMO.
Since then I also went with the shifter upgrade and cable end upgrade and they totally transformed my OEM Short Shifter to perfection.
I have the transmission mounts (ORANGE) but won't get them installed until the spring.
Luca the owner of FF is great to deal with too. Support during the shifter mod/install was outstanding.
One interesting discovery is the past events of the Rennline RSS mounts being resold in the MP here.
I'm very curious to see how the RSS' feel since NVH can be very subjective and my OEM ones seem to be on their way out. I'm used to straight pipe, a little exhaust drone, turbos spooling, blow off valves and all kinds of noises from my Supra so I'll see how much difference the 997 behaves with the RSS mounts. I looked at the FF ones and even saw the Corteco (two options of polyurethane) DIY mod for a more specific firmness.
https://rennlist.com/forums/market/1202166
Over Black Friday, I actually first ordered the Rennline tuneable mounts (similar to the RSS), but then read reviews similar to yours, saying they have too much NVH. I ended up returning the Rennlines and bought the FF mounts, which I've been happy with. I have noticed even with the FF more NVH at idle, and a small new dash buzz. But it's worth the tradeoff, as they stopped the transmission thump noise that I was getting between 1-2 and 2-3 shifts on my 997.2 manual.
If I think back it was a rattle in the seat mechanism and one behind the seat belt trim on the B pillar.
My car is plenty loud so it wasn't about that.
But in general I didn't want the extra vibration.
The RSS Engine mounts took too much away from the refinement of the vehicle (and I have a very firm suspension with no regrets)
DesmoSD (02-03-2021)
