Deployed airbag issues
Old Nov 17, 2020 | 06:57 AM
MRWDXB's Avatar
MRWDXB
Default Deployed airbag issues
As part of my current project, I have an airbag warning light come on. I'm in the process of bringing a neglected 997.1 C4S back to life. It was previously in at least one bump. There is no chassis damage but I've replaced both front wings and the front bumper. It looks like the previous owner removed the airbag wiring and cut one of the internal wires to prevent the warning light showing. The garage that is doing a lot of the technical work has repaired the cut wiring and replaced the airbag wiring loom with a new OEM part. Unfortunately the airbag light has come on and is staying on. Does anyone have any advice on why this might be the case?
Old Nov 17, 2020 | 01:06 PM
ejabour's Avatar
ejabour
Scan it. See what codes pop up.
Old Nov 18, 2020 | 09:19 AM
Petza914's Avatar
Petza914
This. And airbag warnings won't clear on their own even if the issue is corrected. They have to cleared with a scanner. The seat belts have pretensioners in them that are also part of the SRS system.
Old Nov 24, 2020 | 04:57 AM
MRWDXB's Avatar
MRWDXB
Current codes are:
80CB Trigger unit faulty
8038 Drivers front airbag stage 2, below lower limit
8073 Drivers front airbag stage 1 connected to other ign. Circuit
8074 Drivers front airbag stage 2 connected to other ign. Circuit
Old Nov 24, 2020 | 09:13 AM
Petza914's Avatar
Petza914
I've never seen codes like that before. Seems like the car was in an airbag deploying accident and instead of replacing the parts to bring it back, the whole system was just bypassed. Did you know all of this when purchasing the car and decided to buy it anyway?
Those 2 codes about thing being connector to alternate sources seem like the wiring still isn't right, even with the new loom, but I'm just guessing.
Did they scan it with a Porsche compatible scanner as none of the codes start with a P Sonim wondering how accurate those codes are.
Old Nov 29, 2020 | 05:31 AM
MRWDXB's Avatar
MRWDXB
Good questions. I bought it ay auction at risk. As a result it was relatively cheap but issues were anticipated. That wiring issue sounds like it might be right. The previous owner had cut some of the wiring to make the warning light go off. Call me fussy but I'd rather fix it and have an airbag that works. Does make you wonder what goes on in some peoples minds.
I'm not sure what sort of scanner was used, I was just sent a screenshot. I'll look into it a little more
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
