997.1 911 Turbo Foxwell Factory Coding
I'm wondering if anyone has a list of the factory coding that come standard on the 997.1. I reconfigured a lot of items last night and now my vehicle will not lock. I assume it has something to do with the comfort locks however I'm uncertain. When I press the button to lock the button it tries to lock (light blinks and actuators sound like locking) the vehicle, but is unsuccessful in locking. Any idea's on what I may have off. The comfort close and comfort open are now disabled but still doesn't work. Also, I've noticed that the Foxwell will now, not read the Rear so I have to assume there is a fault in there. Here is the coding map I have found.
- DME
- customer specific setting
- cruise control
- PDK (tiptronic)
- (no coms)
- PSM
- (Function terminated)
- PAS
- basic coding
- country code
- vehicle type
- Transmission type
- central locking system
- relocking time start
- alarm system deactivation
- reaction time key button 2 and 3
- central locking opens with lid opening
- comfort functions
- comfort via radio remote control
- comfort function window
- convertible top function
- door and window comfort function
- Key settings (1-4 individually listed)
- Selective opening
- locking on ignition on
- locking when speed > 5 km/hr
- relocking time radio remote central unlock
- relocking time after lid operation
- basic coding
- Gateway
- vehicle variants
- Control arm
- vehicle model
- vehicle type
- required control module lists
- vehicle electrical system
- rear
- drivers door
- passenger doos
- convertible top
- targa roof
- memory seat adjustment
- front
- tire pressure monitoring system
- steering wheel electronics
- gateway
- air conditioning control
- aws
- PAS
- instrument cluster
- CDR
- PCM
- Chronometer
- DME
- tiptronic
- PAS
- PSM
- Steering Angle sensor
- PASM
- POSIP
- CD Changer
- External bose amp
- phone
- sat radio
- dvd driver
- tv tuner
- navigation
- SBS
- sound exhaust
- pas max
- headlight beam adjustment
- seat heating
- on board computer
- speed control system
- multi-func. steering wheel
- sunroof
- park assist
- vehicle variants
- AWS
- (selected function not supported)
- Convertible top
- (no coms)
- cornering light
- (no coms)
- drivers door
- customer specific settings
- memory via radio
- mirror memory function
- lock with safe function
- synchronized mirror adjustment
- mirror lowering
- close comfort
- open comfort
- inner door handle when driving
- manual transmission
- vehicle model
- vehicle type
- ambient light
- window short stroke by lug comp operation
- comfort locking via key
- comfort opening via key
- rattle prevention
- door entry light
- inner door handle
- Front
- Customer specific settings
- individual memory
- side marker or flasher repeater
- switch off fog light for high beam
- home function with
- HBA steering angle sensor
- front lid emergency release
- daytime driving light is mandatory
- front direction indicator light type
- headlight type
- Park assistant
- (no coms)
- Passenger door
- memory via radio
- mirror lowering
- close comfort
- open comfort
- vehicle model
- vehicle type
- ambient light
- rattle prevention
- door entry light
- inner door handle
- POSIP
- drivers thorax airbag
- passenger thorax airbag
- head airbag drivers side
- head airbag passenger side
- drivers side front airbag stage 1
- passenger side front airbag stage 1
- drivers side front airbag stage 2
- passenger side front airbag stage 2
- pretensioner for drivers seatbelt
- pretensioner for passenger seatbelt
- drivers side sensor
- passenger side sensor
- drivers front sensor
- passenger front sensor
- aws
- belt buckle drivers side
- belt buckle passenger side
- right/left hand drive
- key switch passenger airbag off
- PTM
- (no coms)
- Rear
- vehicle type
- country code
- transmission
- slide/tilt roof
- spoiler
- rear wiper
- auto rear wiper in reverse
- alarm system
- inclination sensor
- acoustic alarm output
- seat memory
- (no coms)
- steering column switch
- tiptronic
- multifunction or sport/launch display
- headlight washing system
- push-to-talk
- rear wiper system
- targa roof
- (no coms)
- TPM
- (no coms)
- unit support
- (no coms)
- vehicle elec systems
- vehicle type
- individual memory
- left seat heater
- right seat heater
- diffuser lens washing
- heated rear window and/or mirror
- rain sensor
- rear spoiler
- sport
- rear lid interior light
- garage door opener
- garage door opener county coding
- DME
You might want to read this thread and you might find your answer but for your problem with “rear” look at post 73, 74 & 82. I lost the ability to access “rear” when I tried to change from horn to siren which didn’t take then locked me out.
https://rennlist.com/forums/997-foru...-software.html
First use the Foxwell to scan the car in order to see what codes appear, you don’t have to buy the durametric if you know someone or a shop that has one so they can clear the code(s) for you. Or as a last resort if you’re friendly with a dealership they might clear them for you for free.
My experience with the Foxwell scanner for programming is that it's decent enough for basic programming as in my case to turn off the seatbelt chime and most other basic functions. Issues can and will arise if you attempt multiple programming changes and or less popular programming features with it.
For this reason I don't go to crazy with it on my cars and usually confirm what I want to program has been done already successfully before I guinea pig my car.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20201101_213701_a3538647682f2f7c857a56884b04c0a457426af7.jpg)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20201101_213731_5a27b4850f264c6cc9571832ba526d857d4b8bb4.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20201101_213744_68d140cbc1782fc5d84ff50c75f17a1aad39ba75.jpg)
you will need to use Durametric software to fix the coding error for the Rear module in order to get back in. below is the rear Alarm setting which also affects the locking function:
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20201101_213811_6681171f95434ac5de413275f91e8f8fbfcf26d8.jpg)
08911TurboCab (11-02-2020)
Somehow ended up posting on the totally wrong thread.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Hey there @jyc819 I know this is an old thread but I’m curious if the comfort function soft top works for you?
I have that setting active along with the other comfort functions, which do all work for me, but that one isn’t working for me.
Is there any other place a setting needs to be made to have this function enabled?
only the key opening the windows up and down will work
sunroof, softtop , will not work.
I'm only able to operate the windows as well. Haven't figured out how to operate the soft top with the remote key. I suspect for our MY it doesn't support that functionality. Those with three button keys will be able to remotely operate the soft top.
