Codes U0155, U0146 and U0418
My 997.2 PDK is make a clicking noise when in Park. When I press the brake pedal, I hear a click when and press the pedal and when I take my foot off. The sound appears to be coming from the gear selector. I am getting the 3 codes above which may not be related as only the last one is brake related so I believe.
Any help would be much appreciated.
The clicking is normal. It's the safety release that makes sure you're stepping on the brake before the car let's yiu shift out of park.
You have 3 very unrelated codes there. One is for gauge pod communication, one for a brake controller communication fault, and one for a communication network problem.
What was recently installed into the car - new PCM unit, bluetooth module, track timer, video system, etc Sommething was not tied into the can us network correctly and is causing these communication faults. Either that or your battery voltage is low. How long has the car been sitting since the last drive. How old is the battery.
Low on battery from being unlocked oem from the shop not keeping it on a tender while servicing.
The clicking was never there since I bought the car 3 years ago. Why would it be making the noise now?
It happens when i press the brake pedal and then again after I release and only in Park.
