Bonnet pull is broken
1. Is there a way to just replace this piece without replacing the entire assembly?
2. The bonnet didn’t open when I pulled on the tab. Any idea why?
The switch activates near the hinge. I "fixed" mine with a piece of tie strap and super glue.
That got broken when the car was in for bonnet repainting after a sandstorm incident (see paragraph one).
Since then I've learned to push down at the hinge with my thumb as I lift up at the front with my index finger. This reliably operates the switch.
At some point I may replace the assembly. Right now there is not an immediate need.
But I do feel a bit guilty leaving this as it is!!!
There are previous threads that discuss swapping this assembly out. Loosen the screws on the side of the assembly ... Don't completely remove them. Swap in the new assembly. Tighten.
I purchased a switch on eBay for $50 supposedly was OEM. All is good. Super easy to do. YMMV
https://rennlist.com/forums/997-foru...id-switch.html
Peace
Bruce in Philly
