997 smelling like gas from outside
Owned BMW's all my life and very familiar with them but this is my first Porsche I've ever owned so still not very knowledgeable. I own a 2007 997 with a 4.0 engine in it with only 3k miles on it. The car runs and drives perfectly but I do seem to have an issue with it. After coming from a drive and parking the car back in my garage, there is a strong gas smell that stays in the garage almost as though there is gas leaking from somewhere. I don't see any visible leaks or gas spills on the ground anywhere and I can't seem to pin point where it's coming from by smelling. I tried smelling near the gas cap, engine, exhaust but the smell doesn't really get stronger. No check engine lights either. Actually the other day, I just had to turn the key to the start position and not even start the car and I was smelling some gas outside. There is no gas smell that comes inside the cabin at all even before starting or driving or after driving.
Would anyone have any clue where this is coming from? Is it normal for these cars to smell a bit? How should I go about diagnosing this?
I do have a fabspeed intake and AWE exhaust. If there's any additional information you need that may be helpful please let me know.
Additionally, how could i check the leak in the fuel line? Would i have to jack up the car, take the plastic coverings off underneath and check for leaks assuming the fuel lines run underneath the car?
Thanks for all your help!
If your going to try this yourself there is PDF of the engine diagram somewhere on here that will show you the fuel line locations, but I might just start with a visual inspection when the car is cold, to see if a fitting seems loose anyplace. If you don't know what your engine guy did when the injectors were re-done start with that first, maybe give him a call, but I would guess the two are probably related, as they are both in the fuel system. I believe the fuel filter and some connections are behind the coolant reservoir.
I would also not do this inside a garage or near any flammables.
I like @mchrono suggested scent source.Where in car do they hide the carbon canister?
Is the canister servicable? new carbon pods available?
I get a whiff of petrol after a "full tank" drive, at all other times, gas smell is undetectable.
