AGM coding needed in 997.2?
Old Sep 14, 2020 | 09:23 PM
Prairiedawg's Avatar
Prairiedawg
Default AGM coding needed in 997.2?
My battery failed , OK I failed my battery by leaving the ignition on all night and it doesn't seem to be taking a charge. Is there any reason not to go with an AGM battery versus a lead acid. It was about a $20 difference at Costco so I bought the AGM. If it's a problem I can return it no. Meanwhile it will sit until I find out what I should do.
Old Sep 14, 2020 | 10:22 PM
Floyd540's Avatar
Floyd540
Good news, you are fine. Although these are overcomplicated (electrically for sure) cars, they don't care about battery type. Replace it as described in your owners manual and re-learn the windows if needed. Most of these cars have had batteries replaced by the Bosch AGM ones sold at Pep Boys and never a problem.
Old Sep 14, 2020 | 10:34 PM
Prairiedawg
Awesome, Thanks for your help
Old Sep 15, 2020 | 02:50 AM
gasongasoff's Avatar
gasongasoff
I've only used AGM's in my 997.2S. Never did any coded. No problems.
Old Sep 15, 2020 | 09:36 AM
Petza914's Avatar
Petza914
I no longer have a single lead acid battery in any of my vehicles - all AGM. They're so much better. I didn't have to do any coding or even a window reset when instslling them into my 997s or Cayenne.
