Yeah that's the same one OP mentioned that he bought. Certainly a less expensive option vs a $200 set of torque adapters! It also looks very sturdy with the set screws. Might be a LITTLE nervous on some of the bolts that get torqued closer to 100 ft lbs using that but it would probably be fine. I think the only down side to it is that it's a bit bulky and you have the other part of the wrench hanging off, potentially getting in the way.
