Front Lower Lip
Old Aug 2, 2020 | 02:00 AM
groovzilla's Avatar
groovzilla
Default Front Lower Lip
All,
Quick question----> My front lower Rubber bumper lip split today and dragging on ground from friends low driveway
Found replacement on Sunset Website and ordered--->Looks like a quick "Snap-in" replacement.
Anyone replace one? and hints
Thx in Advance
Old Aug 2, 2020 | 08:11 AM
David Berry's Avatar
David Berry
Originally Posted by groovzilla
All,
Thx in Advance
mine came off in the middle once from hitting the street. It was hanging loose in the middle but secured on the ends. When it was up on a lift I was able to determine
that on the drivers side it is secured by a torex
screw. First install the many inserts into bumper, there are many, requiring you to stretch the lip to each insert. Then secure with torex screw. Not very difficult. Tried to do it myself after removing entire lip. Found it easier
with four hands, needed synchronized inserting of all the inserts.
Old Aug 2, 2020 | 11:03 AM
Iceter's Avatar
Iceter
Super easy. Several tabs across its length that insert into holes in the front fascia. Slide the whole thing over and then secure with a screw.
Old Aug 2, 2020 | 10:41 PM
groovzilla's Avatar
groovzilla
^^Thx guys!!
Old Aug 3, 2020 | 01:51 AM
G.I.G.'s Avatar
G.I.G.
Dumb question: which direction (towards driver's side or passenger's side) do you slide or shift it? Also, where is the screw that secures it? When I bought my car, it didn't have one and I bought one from Pelican. I just snapped it into place, but I notice it keeps working it's way out. It fits in the center channel in the front bumper properly, so I'm not sure if I can shift it to the left or the right? If there was a way to secure it into place, that would be helpful.
Old Aug 3, 2020 | 11:04 AM
Iceter's Avatar
Iceter
Looking at the front of the car, the lip slides towards the left (passenger) side and the hole for the screw that secures it is to the right (driver's) side.
Old Aug 3, 2020 | 12:25 PM
OKB's Avatar
OKB
when ever you need to replace a part, get the new part and look at it and see the way it is attached and what you have to do to take the old one off
Old Aug 3, 2020 | 01:58 PM
G.I.G.'s Avatar
G.I.G.
Iceter, do you have a .2 or a .1? I have a .1 and I believe Groovzilla does as well.
I had accidentally purchased the .2 lower lip initially.
.2 Lower Lip
But this is the one that fits the .1
.1 Lower Lip
You can see on the pic of the .2 lower lip, there is a screw hole, but not a screw hole on the lower lip for the .1. On the .1, I think it just pops into place by pushing it into the grooves in the bumper, and there is no screw securing it in place to the best of my knowledge, which probably explains why we loose them so easily on the .1's. LOL
Old Aug 3, 2020 | 03:32 PM
Iceter's Avatar
Iceter
So sorry GIG. In my effort to be helpful I led you astray. When Groove first asked his question I thought he had a .2.
My car is a.2 and you are correct that the lips are different. The earlier one looks like it snaps in and I don't know if it uses any retaining screws. Sorry about that.
Old Aug 3, 2020 | 03:43 PM
ilovemaui's Avatar
ilovemaui
Very easy on the 997.2. Currently have the 991 lip. It rubs a tiny bit coming into my garage but hanging in there.
Old Aug 3, 2020 | 06:26 PM
G.I.G.'s Avatar
G.I.G.
No worries! I just wanted to confirm because I thought I might have overlooked something on mine.
