C4S axle diy advice.
Long story short, when doing some work investigating a washer fluid leak, as I was putting my wheel back on I noticed a good bit of grease inside the rim. Felt my cv boot and it’s gashed. I am pretty sure it happened sometime in the last 500 miles, but I don’t know. When I pulled my hand out, the grease was black and gritty.
the question is will it be ok to rebuild if everything looks fine once cleaned up, or do I need to buy a whole new axle? Price wise it’s about $650 more, and due to the cathartic nature, I’m inclined to rebuild it. After a few specialty tools it’s probably more like $400 difference. What am I looking for to determine if I can get away with just replacing the boots once I have the axle out?
thanks in advance for the advice.
I think the OP dug right in and figured it out. Nice write up @Brainz .
https://rennlist.com/forums/997-foru...l#post16733328
lol! Yep! And then some. Priciest washer leak ever!
TheTorch (06-29-2020)
Insomnia tonight. I never updated this job. I decided to pull both axles while I had the car on the lift, and when jiggling the passenger side axle out of the wheel carrier I had a real scare. The entire differential half shaft popped out of the diff. Scared the hell out of me, but after some reading I learned that they can indeed pop out, and is necessary to pop out when replacing the seals. Just a funny but scary incident.
sigh
sigh
You're a brave soul to tackle the axles. When I PPI'd, my C4S, I was informed I needed to rebuild my front ones. Having performed a multitude of DIYs on the Audi and BMW side, I finally caved in and let my Indy shop perform the work. It's not easy and requires a few specialized tools like you mentioned. Plus...working with grease sprayed all over your axles, shock-body, wheel well, etc, is never a fun task. Cheers and well done!
