Best way to eliminate understeer
Old 06-19-2020 | 02:51 PM
bgoetz's Avatar
bgoetz
Originally Posted by roadie13
I run RE71s 245/305 on 19 inch wheels and I'm happy with them. I run slightly higher rear pressures than most, I think, to get the rear a bit more mobile.
Good info! I have 15mm spacers all around, wonder if the 245s clear with them.
Old 06-19-2020 | 02:52 PM
roadie13's Avatar
roadie13
I run no spacers; 15mm is probably on the higher side of what could work.
Old 06-19-2020 | 03:03 PM
Doug H's Avatar
Doug H
Remove rear toe that factory dial in to create understeeer as a safety net.
If you say it does not rotate with trail braking, there is something wrong with alignment or worn/tired suspension parts. I have zero problem getting a 997 to turn in and find it very neutral with throttle steering even with factory rear toe.
Where are you feeling the push the most and what type of turn?
Old 06-19-2020 | 03:21 PM
bgoetz's Avatar
bgoetz
Turn in/mid corner, mostly low speed corners like the Keyhole at Mid-Ohio. Sure trail braking helps, but you shouldn’t be forced to trail brake to get a car to rotate. Admittedly coming from an S2K the 911 will always underwhelm in this department, but I am confident I can get it closer to what I want with a few small tweaks.
Old 06-19-2020 | 03:39 PM
Doug H's Avatar
Doug H
I would first remove the rear toe and go neutral. You should be fine mid corner with just maintenance throttle and throttle steer unless blew corner and trying to make up for it with too much throttle to get back up to speed. I get a very even, neutral slide at 10/10s plus mid corner if I am on my marks, have car balanced at truly at 10/10s and just over. If off and trying to make up for it with too much throttle, then push.
Slow corners with long entry way you should be able to get turn in with a little LFB if you feel a slight push and with small back and forth steering inputs until front grips. Should turn if settled though. Cup car and GT3s can behave a little different so make sure getting advise from someone driving same set up as you.
Old 06-19-2020 | 03:41 PM
ADias's Avatar
ADias
Assuming a factory alignment, you can reduce understeer by minimizing rear toe-in (that will also reduce/eliminate inner rear tire wear).
But... contrary to what most 911 new drivers say... a properly aligned 911 does not push if driven correctly. Most new drivers over drive them approaching a turn and cause understeer. 911s should not be over-driven in any way. Of course class/early 911s even less...
Old 06-19-2020 | 05:25 PM
semicycler's Avatar
semicycler
Is your car lowered? It makes the front end understeer worse
Old 06-19-2020 | 05:42 PM
bgoetz's Avatar
bgoetz
It is not but that is good info
Old 06-19-2020 | 06:35 PM
bgoetz's Avatar
bgoetz
Again, these cars are not setup optimal for performance driving, hence different setups on the GT cars. I will definitely check toe, on the S2K you needed toe to not kill yourself.
I am not really interested in the “driver mod” suggestions. It isn’t arrogance it is just that I am confident in my abilities, between sitting in the right seat and driving, I would venture to say i have had more seat time than most people. I am probably a bigger critic of my driving than most and admit I can most definitely gain more experience with the car, but it does not handle how I want, which is why I made the thread. While I understand very well how to tune a suspension, I recognize there are many ways to skin a cat some better than others, so that was the real intent is to figure out the best way on a 997.
Old 06-19-2020 | 09:19 PM
ADias's Avatar
ADias
No one is doubting your ability and skills. But you came here trumpeting your S2k track experience. 911s have drastically different driving dynamics, but that's OK.
Old 06-19-2020 | 09:21 PM
TheTorch's Avatar
TheTorch
@bgoetz RWD or AWD 997 ?
Old 06-19-2020 | 09:51 PM
bgoetz's Avatar
bgoetz
I never “trumpeted” my S2K experience, the S2K was my track car for many years so of course it was the car I had the most experience in. I have driven many other cars around the track, but it isn’t the same as driving your own car .
Like I said, not trying to come across as arrogant, I am just really interested in one thing and that is making this car handle a bit better. Totally agree part of it could be coming from a different car, but I do know that people who track the non-GT cars typically make adjustments. This car isn’t perfect for the track out of the box, but most cars aren’t.
The following 2 users liked this post by bgoetz:
RacerWannabe (06-28-2020), VT Blue (06-23-2020)
Old 06-19-2020 | 09:54 PM
bgoetz's Avatar
bgoetz
It is a C2S.
I gave a check ride to a guy who was a decent driver and had a GT4 that had a 911 rear end and I just think it ruined me. That car just felt perfect in every single way. It made me wish my 997 felt similar.
Old 06-20-2020 | 08:54 AM
Petza914's Avatar
Petza914
Come into the turn slightly slower than you did in your Honda and get on the gas sooner in the 911. That rear weight bias gives better grip through the turn and on exit, but if you come in too hot with the light front end, it will be harder to get it to bite to where you can get on the gas. Once you have the front end sliding at tuen entry it will continue to push.
The wider front tires and other suggestions won't hurt either.
ADias (06-20-2020)
Old 06-20-2020 | 09:26 AM
1990nein's Avatar
1990nein
Patrick3000 (06-21-2020)
Quick Reply: Best way to eliminate understeer
