Carbon roof quandaries
Old 06-18-2020 | 12:57 PM
jaredomin's Avatar
jaredomin
Default Carbon roof quandaries
Hey everybody, i have finally collected all components necessary to complete the carbon roof/sunroof delete on my turbo.
i am a little confused as to what method of attachment you guys would use to secure the roof.
What type of epoxy would you use for this project?
thanks
Old 06-18-2020 | 01:15 PM
Steve 911's Avatar
Steve 911
I wouldn't guess, I would source the actual repair documentation from Porsche to see how they'd reattach a new roof.
Or just use the same thing the BMWs guys use. You had a CSL roof right, how did you do that one?
Old 06-19-2020 | 08:42 AM
Petza914's Avatar
Petza914
For an epoxy type product, 3M Panelbond. That's how we attached the flares on my widebody Cayenne TTS project. Build thread is on here.
Old 06-19-2020 | 05:54 PM
JCD911S's Avatar
JCD911S
Please document the process, been thinking about doing this too.
Like Petza said 3M panel bond seems to be the adhesive I've read the most good things about whether attaching panels, widebody flares and spoilers.
Old 06-19-2020 | 06:46 PM
jaredomin's Avatar
jaredomin
it will all be documented.
i will most likely going with the 3m panel bond along with x8 99919010430
00004330535
Old 06-19-2020 | 11:53 PM
Skwerl's Avatar
Skwerl
Ideally with your buddy's iPhone camera and not your 2004 Blackberry camera.
The following 2 users liked this post by Skwerl:
bschurr (06-20-2020), jaredomin (06-20-2020)
Old 06-20-2020 | 12:31 AM
jaredomin's Avatar
jaredomin
lmao of course i got you.
i always get the good stuff w the good camera
Old 06-20-2020 | 09:31 PM
halo777's Avatar
halo777
When I looked into carbon roofs for the 997, I'm sure I read somewhere that it is not recommended unless you have a full roll cage. Same with carbon doors.
I can't find the original post, but it was due to safety concerns, IIRC, and the way carbon splinters when it breaks.
Just posting in case you were unaware. Maybe someone can provide the details.
Old 06-20-2020 | 09:33 PM
jaredomin's Avatar
jaredomin
i dont care
i wont have a cage any time soon
Old 06-20-2020 | 09:40 PM
halo777's Avatar
halo777
Ah ok, no problem. Sunroof delete is awesome.
I found the thread, if anyone is interested.... It's for the 996, but same for 997
https://rennlist.com/forums/rennlist...d.php?t=904188
Old 06-20-2020 | 10:56 PM
jaredomin's Avatar
jaredomin
Ive never drilled a spot weld before, any pointers 😂
Old 06-21-2020 | 12:51 AM
JCD911S's Avatar
JCD911S
There’s s drill bit made specifically for drilling out spot welds. Looks like a mini hole saw. But since you don’t need to retain the backing metal since you won’t be welding the new panel on, you can probably start with your smallest drill bit then work your way up the drill bit sizes until you out-size the weld diameter.
Old 06-21-2020 | 01:19 PM
jaredomin's Avatar
jaredomin
Another thing id like to address,
should i put the car on jackstands when doing this?
i was talking to someone and they said i MUST put the car on 4 stands to release any load/preload.
good idea or?
Old 06-22-2020 | 02:58 PM
ejabour's Avatar
ejabour
I have used this tool to drill out a ton of spot welds. Works very good:
https://www.harborfreight.com/38-in-...ter-63657.html
I should say it doesn't drill them out it cuts the sheet metal around the weld on the first layer of steel in the lap joint.
If you put it on stands make sure the ground is smooth and level. If not you could be adding load
Old 06-22-2020 | 10:57 PM
jaredomin's Avatar
jaredomin
Piwis states that if the car is structurally sound you can remove and install a new roof panel, with the car on a level surface resting naturally on its wheels.
i am a fair way into this mod and let me tell you, it is a lot of work. Not for the faint of heart.
Quick Reply: Carbon roof quandaries
