06 997.1 Cabriolet S Window Problem
Yesterday I took a long top-down drive. Because of a detour I was forced to drive on an extremely bumpy road. When I returned home I went to raise top when the back quarter windows raised up as usual, however the right & left front windows did not. I tried each of the window switches, the row A #1 and #4 fuses(not blown), and could find no cause of the failure. I tried all the windows again today with no luck. Any thoughts?
I'm no expert, but it sounds like something may have rattled loose in the actuator switch(es). I know they can be twitchy, as my passenger 1/4 window is a "sometimes yes/sometimes no" issue. Not sure how to go about testing, but I will follow this thread to see if I can learn something!
Disconnect the negative battery lead for 10 minutes, reconnect, and try again. DON'T LATCH THE FRUNK WHILE THE BATTERY IS DISCONNECTED - put a folded up t-shirt or something there to prevent it from closing out of habit.
