Need help - Installing Ecliptech ShiftP2 shift light in 997.2
Recently purchased an Ecliptech ShiftP2+ shift light to install on 997.2. Had one on my 997.1 and found it to be invaluable. Was great to have the visual reference during DEs and other situations where it may be challenging to read the tach or hear the engine while navigating tight corners or traffic.
I understand the installation is quite different for 997.2 compared to the 997.1 so was looking for anyone that can offer any guidance on this process. The ground and power looks pretty straight forward - running down to the fuse panel, however I am looking for recommendations on where to connect the blue wire (ignition/rpm output). In the 997.1 this connection could be made under the passenger seat at the ECU but see that does not apply to the .2.
Any suggestions?
Any suggestions?
