P&P Throttle body and Plate
Not sure if this applies to 997s, but I know a bunch of the Evo guys messed with their throttle bodies only to discover there's some factory gunk on the plate that ensures it's sealed when in the closed position. If you remove that, you're stuck with a leaky throttle body which causes all sorts of driveability issues.
I bought a junkyard TB off eBay for this DIY too.
Alright. The good news. It works great! No codes, idle is perfect, trims are good.
the bad news- it straight up whistles at 20% throttle. I mean it whistles lol.
would be fine for a race car.
That's great DIY, and you guys seem to be getting the right results too. We do these too, in case you want to skip the work and have them optimized. We do this of all TB sizes, including the GT3, we optimize and increase from 82mm to 86mm. Please visit our site or search our threads here.
Stock (left), Soler Performance Modified (Right)
Thanks,
The Soler Performance Team
support@solerengineering.com
https://www.solerengineering.com/
(727) 667-9225
Thanks,
(727) 667-9225
That's great, DIY and you guys seem to be getting the right results too. We do these too, in case you want to skip the work and have them optimized. We do this of all TB sizes, including the GT3, we optimize and increase from 82mm to 86mm. Please visit our site or search our threads here.
Thanks,
(727) 667-9225
Thanks,
(727) 667-9225
Hmmm, do people use your GT3 with the IPD Plenum?
It can be used wherever there is the GT3 throttle body hole pattern and bore diameter to receive it. Or, if the plenum has the 74mm TB hole pattern and bore, you can use our Adapter Kit in between the plenum and our GT3 TB.
Thanks,
(727) 667-9225
Thanks,
(727) 667-9225
Thanks,
(727) 667-9225
Thanks,
(727) 667-9225
