P0503 code after using fuse tap
Old May 12, 2020 | 07:14 PM
nlenard's Avatar
nlenard
6th Gear
Default P0503 code after using fuse tap
Hello, I tried to do the add a fuse approach to hardwiring a Uniden radar detector mod on a 997 as it sounded very straight forward but I accidentally put the fuse tap into the d7 fuse. I quickly switched the tap to C6 but now I am having a CEL with the system saying their is a system fault, PASM failure. What should I do? I replaced the fuse into the D7 slot and on an OBDII app that I have, it is throwing a p0503 code which is "vehicle speed sensor a erratic/high". Please help!
Old May 12, 2020 | 08:31 PM
raspritz's Avatar
raspritz
Originally Posted by nlenard
Hello, I tried to do the add a fuse approach to hardwiring a unidentifiable radar detector mod as it sounded very straight forward but I accidentally put the fuse tap into the d7 fuse. I quickly switched the tap to c6 but now I am having a CEL with the system saying their is a system fault, pasm failure, and spoiler failure. What should I do? i replaced the fuse into d7 and on an OBDII app that i have it is throwing a p0503 code which is vehicle speed sensor a erratic/high. Please help!
The cars on this forum don't have d7 or c6 fuses, PASM, OBDII ports, sensors, or codes of any kind. Just sayin'....
Old May 12, 2020 | 09:21 PM
nlenard's Avatar
nlenard
6th Gear
No, I don't. What are you saying?
Old May 12, 2020 | 09:36 PM
nlenard's Avatar
nlenard
6th Gear
Got it. New to the forum, sorry about that. I understand now.
Old May 12, 2020 | 10:08 PM
OCNYPORSCHE's Avatar
OCNYPORSCHE
Moved this thread from the 911 forum to this forum as it is a 997 relevant thread
Old May 13, 2020 | 05:55 AM
bschurr's Avatar
bschurr
your answer lies here —> https://rennlist.com/forums/997-foru...-fuse-box.html
