View Poll Results: Best manual transmission gear oil for a 997.2?
Mobil Delvac
0
0%
Mobil 1 PTX
22
84.62%
Motul Gear 300
1
3.85%
Liqui Moly GL5
3
11.54%
Voters: 26. You may not vote on this poll
997.2 Gear Oil
Old 04-07-2020 | 10:01 AM
Hindsight2010's Avatar
Hindsight2010
Mobilube PTX is the oil spec'd for these transmissions. It is special for these transmissions which are manufactured in Japan by Aisin.
Like others, I changed my factory fill of PTX for a fresh fill of PTX and it made no difference in the shifting. Installing a Numeric Racing shifter and cables took away the 1-2 grind that would happen when cold, but it can still be tough to get into 1st and 2nd when cold. This is just a known quirk of these transmissions. I read somewhere it is because they use steel synchros for 1st and 2nd for durability purposes - stronger than brass but also harder to shift especially when cold. You can't really fix the issue with an oil change, but an oil change is a good thing to do for the longevity of your transmission.
Old 04-07-2020 | 11:00 AM
Mike Murphy's Avatar
Mike Murphy
Originally Posted by Bruce In Philly
1st gear is designed to lock out when rolling. Your car is working as designed.
Peace
Bruce in Philly
Maybe, but there have been many owners that don’t seem to have this problem. And then when the car warms up, first gear is attainable.
Old 04-07-2020 | 08:34 PM
bheit1's Avatar
bheit1
Most gear oils will meet the quality required. The difference with PTX is the viscosity which functions well with the Porsche synchros.
Quick Reply: 997.2 Gear Oil
