997 Billet aluminum gunmetal cap covers
Inspired by Pete late last year when he committed on his.
It has taken me a few months but I finally found a set on EBay.
Engine oil, power steering and antifreeze caps.
Sweet. Glad you found a set.
When you go to install them, back the screws out far enough where they slip right over, then turn the screws in far enough to mark the plastic, then remove them again and take a drill bit that's just a hair smaller than the set screws and make a really short hole for the set screw to go into a bit. This will keep the caps on more securely and prevent the set screws from pushing out on the metal, which doesn't look as good.
Yea rookie move #1. Rennlist members learn from this. On the antifreeze cap I put it on upside down. Do not push all the way down on the cap. I can not remove that one & put on facing up. I took the picture w/ that cap on lose for the photo.
Thank you again Pete. I’m glad to have a set.
