Request for Info ... retrofit
Greetings -- can someone please id the two (2) item in the attached photos and can a 997.1 coupe Bose be retrofitted with same.
One appears to be a storage item - the other is interesting given the versatile receptacles -
Thanks in advance .as always for any insight .....
EJ
EJ
The first picture is the front subwoofer that is found on targa & cabriolet only. The coupe has a larger subwoofer behind the rear seats. I'm no expert, but given it's a bass reflex design, I assume the coupe is more "true" to the intended sound quality design and the targa/cab is a compromise since the original/larger sub location behind the seats is not available. So it probably isn't worth the hassle trying to retrofit/add the cabriolet sub into a coupe.
Duh ........ got it !
Have the Bose sub as indicated - just have not seen same before - spoke to a "install guy.." the third pic item will not work unless upgrade to a later PCM or replacement radio .... all good saved $$$ LOL
Thanks to all .
EJ
Thanks to all .
EJ
