PSA: Change your belt pulleys!
A buddy had his belt tensioner explode today. This is what I found in the engine bay...
He said he heard a bang and then lost power steering. Luckily no collateral damage but the belt is wrapped so tightly around the crank it needs to be cut off.
He had the belt replaced 5k miles ago but didnt replace the pulleys. While I was in there I noticed his water pump was also going bad. He said he replaced it 10k miles / 4yrs ago. It ran free but I could see residue all over the top of it and the bearing had some play. Whats your vote:
A) A bad water pump bearing caused the tensioner to explode
B) A bad tensioner bearing caused the water pump to leak from excess vibration
C) None of the above. Just a ****ty day...
Note to self: replace those pulleys!!!
DesmoSD (02-25-2020)
Vincent713 (02-24-2020)
Parts from my sons '07 C2S. Idler pulley blew apart snapping the belt. Belt contacted the oil fill tube breaking it in two. The pulley wheel is a plastic material. After seeing that I had the tensioner and idler pulley's replaced when I had a new belt installed on my '06 C2S.
