After successfully installing the DSC sport module and accelerometer in my 2006 997.1 s manual coupe the air bag error light will not go off. I tried unsuccessfully to erase the code with my icarsoft scanner. The scanner said I need part # 99761821708. None of the modules under the seats match that part as per my internet search. I'd appreciate any help on where it's located.
@Mreul I completed the install of a numeric short shifter on my manual 997.1 TT and I am having the same issue with the driver airbag light not turning off after ignition. Were you able to resolve the issue?
