What I found on center locks
The rear tires were at the "cords will appear in the next 50 miles" stage so we opted to pass this problem off to our tire guy.
This morning the tire guy failed as well, using a 4 foot pipe for extra leverage on the breaker bar.
So the car went to our trusted Indie who simply said "Yeah, some do that" as he picked up his 6 foot extension pipe. He also picked up his heavier breaker bar.
So picture 180 to 200 pounds jumping up and down at the end of a 6 foot pipe. Note: The pipe was sleeved over the entire breaker bar to avoid over flexing and breaking it (the bar).
Yes, after some effort the center lock nut came loose. You can do the math for the torque that nut endured [(6 feet minus jumping at 1 foot from the end) times (200 pounds)].
And yes, jumping on the bar to add weight to the tire to help it not lift and rotate. Also, something to be said about damaging your back lifting on the bar. Additionally, going down from horizontal, if the tool slips or breaks it hits the ground rather than the car.
So now the new PS4 tires are being installed. Then we can tackle the services assuming we'll be able to pull the wheels.
Lesson ... Be ready to use some force if you have center locks. The 450 pound feet is merely the initial torque placed on the nut during installation and apparently this value can increase while driving. The special factory tools might need to be augmented with a long strong pipe. And the special factory breaker bar comes in two flavors ... Make sure your bar has the ratcheting head.
I think I'll stick with my lugs 8)
It uses a planetary gear set to multiply the input force by 3x to the output. (Though you have to move the input torque wrench 3 times as far as the output turns). It's a must for anyone with centerlocks, say good bye to six foot breaker bars and gigantic torque wrenches. Best of all, it and a normal sized torque wrench fit nicely in the bottom of the frunk without taking up much space.
There have been some concerns about accuracy as any error on the input torque wrench will be magnified 3 times. Use a good quality input torque wrench not the $25 Harbor Freight el cheapo model. I did the long breaker bar thing one time and that was enough, ordered the torque multiplier the next day.
I didn't have any issue taking off my centerlocks with ease. I do have a long torque wrench. I didn't need special factory tools. I didn't need to use any breaker bar.
The other thing to keep in mind with centerlocks is that the nubs on the hub (probably have a technical name) that prevent the wheel from turning are a wear item that need replacement from time to time (don't know the interval or if it's just an "replace as necessary" directive). In either case, other than faster pit crew wheel changes on a track, I don't see the purpose or advantage of centerlocks on a street car or even a amateur racer car, other than some people think they look cool. I don't need to be that cool.
The only down side I see with them is the inability to add spacers. Sucks about the experience Wayne's friend had with them, but it does sound as if they were not properly reinstalled.
Porsche dealer charges $40 per wheel to mount, balance, rotate and etc. the center lock wheels. My local Independent charges the same. $160 for 4 to have it done correctly seems like a small price to pay to have a wheel that I like and my dealer actually has the N rated tires cheaper than Tire Rack.
Good story..... I wanted the center locks when I saw them. I think they look great but then read up on them and they appeared to be a nightmare.... if I get a flat out there etc.... have to buy a tool that shops may not have... etc etc
Porsche is starting to give us "performance" options that simply are not. Cost with little value.
Peace
Bruce in Philly
Porsche says the alignment nubs must be replaced with every rotor change but there's some healthy skepticism on the boards if this is really required (provided they aren't damaged). They are $175 per wheel from Suncoast so it's not cheap. My previous owner had the rear rotors replaced and the nubs aren't on the invoice (work not done by Porsche) so it looks like they were reused on my car. No issues so far that I can tell.
I forgot about the torque multiplier and it is a tool not found in any of my tool chest drawers. That's a great idea that belies the fact that so much torque was required. But definitely the multiplier is a tool that would be a good choice for anyone with center locks IMHO.
With all of the comments I'll put in a different thought. Having been a skeptic regarding center locks, now that I've had a brief chance to play with them I'm much less a skeptic than I used to be. Would I opt for them if given a choice? No. But if a 996.2 TTS showed up with center locks I wouldn't reject the car either!!!
