HELP! 997.1 in limp mode with multiple CELs
Old Jan 11, 2020 | 03:12 PM
Oldmother's Avatar
Oldmother
6th Gear
Default HELP! 997.1 in limp mode with multiple CELs
All,
I could use some help with my new to me 2005 997 (3.6--2006 build date). I replaced the bank 2 downstream 02 sensor last week after a P0161 code popped the CEL. Unfortunately this didn't fix the problem, and the CEL with the same code came back within 100 miles or so. After running some errands with the car this morning, I decided to investigate further. Pin 1 had 1.25 volts with the car running. I could not get a good resistance reading on pin 2. I took a look at the wiring just behind the female plug that goes to the wiring harness and saw lots of electrical tape, so naturally I investigated. The 2006 plug is different from the 2005 version, and whomever had put the 2006 motor in had just made the connection for the updated plug with electrical tape. I took all of this off, cleaned up the wires, and soldered them, hoping this would solve the problem. I then wrapped the wiring with non-stick electrical tape and reconnected the 02 sensor. After taking the dog for a walk, I went to take the car for a test drive. The car wouldn't rev over 1800 RPM, and threw the following codes: P0158, P1091, P0132, P0138, and P0152. I checked the fuses--they were all ok. I then disconnected the battery for 30 minutes or so to reset the computer. I started the car again, with similar results--the car still stumbled and would not rev over 1800 RPM, this time throwing P1091, P1175, and P0132.
I did not take the airbox off while doing the wiring repair.
What happened?? Please help!
Andrew
Old Jan 11, 2020 | 10:54 PM
rtl5009's Avatar
rtl5009
Originally Posted by Oldmother
All,
Andrew
you have to be very careful with heating wires as if it’s hooked up wrong you can introduce undesired amperage direct to the ecu board and cook it.
I would recheck your connection.
Old Jan 12, 2020 | 02:17 AM
Oldmother's Avatar
Oldmother
6th Gear
That doesn't sound promising. Which connections should I recheck?
Old Jan 13, 2020 | 12:04 PM
Petza914's Avatar
Petza914
Those are almost all voltage related Oxygen Sensor codes. Seems like you have something wrong with the wiring going from the car to the O2 sensors. Are those the wires where you say they cut and spliced in different plugs? If so, I would buy 4 new oxygen sensors (left pre and post cat & right pre and post cat) with the correct plugs for the boards that are in the engine bay to eliminate all the cut wires and splices. Bet that solves your problem.
