Bore scoring? Video sound
I'm pretty sure I know the answer to this one, but does this sound like bore scoring to you? Whats odd is it doesn't have the same rhythm as other videos I've seen. It burns nearly no oil, and drives perfect and strong as ever (though I know bore scoring and it running poorly aren't exclusive).
https://photos.app.goo.gl/61suu9zh4PG2mfpd6
https://photos.app.goo.gl/uHfHw1u6JDsEUhMr7
Doesn't sound like bore score. Too random and doesn't increase with RPM. Something is loose like a tensioner or water pump bearing. Take it to an indy. I don't think you need to sweat this one. My 2c.
I had the same thought too, since it happened fairly suddenly, and only happened when I was driving over bumps or rough start from first gear.
That is not bore scoring.
Found the culprit, cat is rattle on bank 4,5,6. I can bang it with my fist and hear the same sound, got a stethoscope and its by far the loudest when touching the header & catalytic converter. I put it right on the cylinders for all 6 cylinders and they all sound very similar, but as soon as I touch the header or cat it gets 10x louder, and louder the closer I get to the cat.
Time for either cat delete, gut the cats, or new cats...
