Which oil pan upgrade?
Old 12-02-2019 | 10:47 AM
cwheeler's Avatar
cwheeler
Default Which oil pan upgrade?
Trying to decide what oil pan to get. What's you guys opinion?
https://lnengineering.com/products/m...51-baffle.html
Or
https://www.fvd.net/us-en/FVD2079880...t-oil-pan.html
Cw
Old 12-02-2019 | 12:11 PM
Hella-Buggin''s Avatar
Hella-Buggin'
Not sure what model you have but the FVD doesn't fit a 3.8 engine. If it's going in an S car than that leaves the LNE or Mantis. Otherwise I'd go with the FVD.
Old 12-02-2019 | 12:34 PM
cwheeler's Avatar
cwheeler
Oh man. Good call. Thanks.
This is for 08 C2 S.
http://www.mantissport.ca/ProductPor...4/Default.aspx
The downside to the mantis, is that you reuse the stock baffles.. but you get a windage tray. I don't think the LN has a windage tray, but includes improved baffling.
Perhaps both/either will be just fine...
Cw
Old 12-02-2019 | 07:11 PM
Quadcammer's Avatar
Quadcammer
neither do much of anything. I've watched my buddy's cayman S drop pressure in turns dramatically with the mantis, just like mine does with the LN style unit (its tune RS with EBS x51 style baffle to avoid the ire of LN). Hard to believe, but I don't see any of these offering much benefit.
Old 12-02-2019 | 07:33 PM
cwheeler's Avatar
cwheeler
Well that's comforting.... I guess I should purchase just in case? Or say, "Eff it" and take my chances?
Cw
John.berg (08-03-2020)
Old 12-03-2019 | 05:33 PM
Petza914's Avatar
Petza914
I have the larger MantisSport version and the LN Stainless skid plate to protect it. Moves oil change refill volume from the previous 8-8.5 quarts to 10 quarts.
Old 12-03-2019 | 07:27 PM
cwheeler's Avatar
cwheeler
Thanks Petza, but I'm looking for the protection aspect. The additional oil is a bonus, but I really just want to track with proper tires and not worry about scavenging.
From the lack of responses, A) no one knows, B) it doesn't matter which version is used, C) my thread sucks.
Cw
Old 12-03-2019 | 07:40 PM
C4SDayton's Avatar
C4SDayton
Cw
can you just get the OEM X51version?
Old 12-03-2019 | 08:31 PM
cwheeler's Avatar
cwheeler
The baffle, yes.
Old 07-01-2020 | 05:31 PM
cwheeler's Avatar
cwheeler
Wanted to update my thread.
I ended up going with the LN 2qt deep sump. I guess its actually a Bit product. https://lnengineering.com/products/m...51-baffle.html
Install was super easy and straightforward.
Take this with a grain of salt, as its just my own experience, but under the following conditions: Bilt +2qt deep sump, Michelin PS4S, Xp-9, Third radiator, low temp thermostat, outside temps 90-97*, oil temps up to about 240* on the gauge, the oil pressure stayed where it should.
The track I ran was NCCAR, https://nccar.us/nccar-facilities/nc...ad-course.html, in both directions.
cw
Old 07-01-2020 | 05:41 PM
ekam's Avatar
ekam
More oil = more cooling.
Old 07-01-2020 | 07:07 PM
Hi-Arc's Avatar
Hi-Arc
Mantis is race proven and excellent customer support.
Old 07-01-2020 | 07:20 PM
kisik's Avatar
kisik
I run Mantis 1.2L + 3d radiator + NT01s + low temp thermostat + Motul 8100 (should switch to XP-9 or V-series) and essentially after 20-25 min I typically get ~ 245F on my OBDII. A bit too much so I pit, cool off and come back. It's just not enough cooling no matter what.
I am pushing it but trying staying on higher gear to lower RPMs to stay cooler. Yes, I have slightly more oil but it just help staying a bit cooler for a few minutes with more thermal oil mass. Not easy. My friends in 07' GT3 has 215F all the time.. no matter what. His center radiator is more thermally efficient by venting on the top.
Not sure what to do. I like 997 platform. By the way 997.2 are pretty much the same. I need to invent water injection system like in new M3s.
Old 07-01-2020 | 07:28 PM
user 729082021's Avatar
user 729082021
I have an '07 C2S with factory X-51 kit, which strangely does not include the X-51 oil pan. I cracked my original pan this past winter and had the X-51 put on as a replacement. Works fine, oils stays in the engine.
Old 07-01-2020 | 08:48 PM
cwheeler's Avatar
cwheeler
As a point of reference, XP-9 is safe to higher than 250*... and like I said, it was nearly 100* for 25 mins sessions and my temp still did not hit 250*.
Quick Reply: Which oil pan upgrade?
