This is probably just me noticing increased vibration at idle since replacing my old and somewhat floppy engine mounts but I figured I'd check for fault codes (none current or pending using Durametric and a generic OBD2 scanner). I graphed the roughness for each cylinder with Durametric and here's a clip from the engine warmed up feeling slight vibration through the seat:
Can anyone shine light on how those numbers look? I don't see a cylinder that's way outside of the others, but 1 tends to be higher most of the time. The engine is totally smooth accelerating part load, full throttle, etc. I have no smoke at startup, exhaust tips don't seem excessively dirty, oil consumption is very moderate. Thanks for any opinions and guidance!
Thanks, Hella-Buggin'. I watched that video but it was a while ago. The 996 in his example seemed to hit 1.2 once or twice and he didn't seem concerned til it got to "4 or 5 or 40". Mine seems to be in a similar range to his good example in the vid.
Following up on this, changing gas brands made no difference. I haven't tried cleaning the TB yet or inspecting the coils/plugs (much more labor-intensive) but I did look up how to log using Durametric and here's a snapshot from this morning warmed up idling after a drive to work:
I would describe the roughness as similar to the subwoofer bass vibrations, if I turn up the music, the roughness gets lost. I'd say I'm not too concerned with values that peak around 1 or -1 but another set of eyes would be appreciated.
My idle is rougher than I imagine OEM should be but I'm at 100k miles (passenger seat has noticeable vibration). I plan to change the engine mounts, clean the TB and air sensor as well as replace the AOS.
I'd bet money new mounts, plugs and a good cleaning is all you need.
