Replacement brake pad options for PCCB
I just picked up a 06 C4S with PCCB. The pads currently have a bit under 50% pad left but are squeaking pretty good. I am going to replace them, but I can only find OEM pads which is fine, but was curious if there are any other options out there for a street driven car.
PCCBs work so well, I wouldn't mess with that formula. Best case, you end up with worse braking. Worst case, you damage the super expensive rotors. Go with the OEM pad offering from Suncoast and you'll be good for another 75-100k miles. Get the proper pronged pad dampeners. Suncoast sells them in front and rear kits with the right mixed sizes as the caliper pistons are different sizes, even within the same caliper.
blk on blk (10-23-2019)
