Engine mounts
Old Sep 30, 2019 | 09:08 PM
teddysam1's Avatar
teddysam1
Default Engine mounts
I have a 05 carrera s, tip, in which I believe have the original engine mounts. I’ve read a lot on changing engine mounts, but for manual cars and PDK. I didn’t see any threads on engine mount changes for tip cars. Are engine mounts being changed on tip cars?
If so, which mounts are people using, wevo, rennline or RSS. Thank you.
Old Sep 30, 2019 | 09:34 PM
laphan's Avatar
laphan
Yes, my old car was tiptronic and engine mount went bad at 70K. Exact same process to replace mounts with manual.
Old Sep 30, 2019 | 09:43 PM
teddysam1's Avatar
teddysam1
Laphan, What mounts did you put in?
Old Sep 30, 2019 | 10:55 PM
Jeremy Hazeltine's Avatar
Jeremy Hazeltine
I went with the RSS mounts, and there is a notable increase in cabin vibrations at certain rpm. With a manual it did help shifting
Old Sep 30, 2019 | 11:56 PM
jeebus31's Avatar
jeebus31
OEM corteco recently went in to my tip turbo. Used the same for my previous manual carrera.
Old Oct 1, 2019 | 12:17 AM
ronvanr's Avatar
ronvanr
I have a 2005 cab, with tip. I Purchased OEM through sunset Porsche. Replacing them was easy. However, I had to wait a bit to get the mounts as the cab engine mount has a different part number than the coup- and of course they were out. My car had just over 70.000 miles on it.
Old Oct 1, 2019 | 12:39 PM
laphan's Avatar
laphan
Corteco mounts
Old Oct 1, 2019 | 10:05 PM
laphan's Avatar
laphan
My current 997 is a convertible and I used the coupe mounts. Exact same dimensions and fit same with original mount.
I am glad that I did not wait for Porsche to get the cab mount. Mine actually cracked and it can let go anytime.
Old Oct 2, 2019 | 09:17 PM
Lvt19672's Avatar
Lvt19672
Rein is also oem and that's what came out of my 05 when I replaced it at 51K miles.
Old Oct 3, 2019 | 11:08 AM
Gmanscott's Avatar
Gmanscott
RSS motor mounts- call Mike if any questions. Great vendor and have purchased quite a few 997 up grades from him. Also, I highly recommend the under drive pulley also an RSS part- see links below. No affiliation... just a satisfied customer.
RSS motor mounts>> https://roadsportsupply.com/624-rss-...engine-mounts/
RSS under drive pulley>> https://roadsportsupply.com/601-perf...6-997-3-6l-na/
Old Oct 3, 2019 | 11:37 AM
RSSmike's Avatar
RSSmike
Former Vendor
Thanks for the kind words and recommendation. We appreciate it!
Old Apr 8, 2020 | 11:59 AM
RSSmike's Avatar
RSSmike
Former Vendor
Default RSS 624 Performance Engine Mounts | Back In Stock!
RSS Performance Engine Mounts, currently back in stock, ready to ship!
See direct link below:
RSS #624 Engine Mounts Direct Link:
Old Apr 8, 2020 | 01:01 PM
Michaelc's Avatar
Michaelc
I used these, OEM, worked great, order them with longer bolts. Porsche Engine Mount - 96437504381 - Genuine Porsche
