seat belt
back in the past I had a belt made by G force that would wrap around a stock seat and help keep you in place , dont really want to take stock seats out for DE's but would like a little more , I cant find them on G froce anymore anyone help here
There's a product called CG Lock that's a sort of belt clamp you can buy that locks the lap portion of the seatbelt in a set position by clamping the belt upstream of the waist buckle. If you then want to also lock the cross-shoulder part, you can pull the belt out all the way which will put it into child seat mode so it only ratchets in, but not out. The CG Lock will rough up the top side of the waist buckle though since the contact with it is what keeps the lap portion of the belt from moving through the slot.
Another idea is to move your seat back a little, pull the driver's belt all the way out to lock it in child seat mode so it only ratchets in, pull it tight and then use the seat motor to push the seat forward and/or up a little bit which will even further tighten it. For an occasional DE that's really all you should need.
Have fun.
Have fun.
