@wayne - how did you fasten the screens? Zip tie or did you screw in from the rear?
@yves - awesome. love to see them. take as spin through the 997 buyers guide and let me know any you want to include there. I have a list of DIY guides and included some of your prior projects.
@Hatzenbach and @driggity thats an interesting observation. I would like to test that too. Have you seen this type of variance on the oil pressure gauge too?
Do you know if this is because they're reading sensors in different locations or is it the same sensor with an offset on the gauge? I'll have to remember to check my car and see if there is a similar delta.
Well when I measure oil temp via the CAN bus the. The measurement is all digital. So my theory is that the analog oil temp gauge isn’t that accurate.
Well, in my car the oil pressure gauge just has a few lines but no explanation what these lines are supposed to mean (PSI?, Bar?)
And it begins. Everything is very fast to remove on the bumper but i'm jammed on the t25 behind the side marker. I only have torx sockets and those are too big to fit in the slot. I need to pickup a torx driver. Bleh.
90% done. Making those damn grill guards took 2x longer than installing the radiator. I paid $6 at Home Depot for the same gutter mesh Rennline charges $300 for. I would gladly pay $294 more next time to save the hassle. Anyway, it looks amazing so it was worth it.
I got hung up re-installing the t25 behind the sidemarker. Its really tricky to manipulate the screw between the slot without dropping it into the fender. Is very un-porsche. I need to tackle in the morning.
