Steep hill start tip for manual 997.1?
I come across some very steep hills here in the east coast sometimes, and with the manual, I find it hard sometimes to make a smooth start off a very steep hill, even with using the parking brake. Then, I thought since I have the Sport Chrono button on my car that increases throttle over stock settings when touching the throttle, that this could be useful when on a steep hill, by quickly adding a bit of extra throttle when in that mode at the hill start.
Tried it out, and it seems to help a bit. Just wondering if anyone else has tried it. I hate stalling on a hill, and even though I’ve driven manuals for over 30 yrs, that still sometimes happens! I think the 997.2 models came with hill hold, so it doesn’t apply to those cars.
If anything Sport Chrono would be a hindrance as it makes fine-tuning throttle input more difficult. The trick is not power but the timing of its delivery. You just need some practice to align the handbrake release, clutch release, and throttle application into a smooth synchronized act. Can't be learned by theory, just practice.
Btw, starting a manual car on a steep hill with a handbrake without any rollback is a part of driver's licence tests in many European countries.
But it's not as simple as more throttle => better. If you add too much throttle then you end up either lurching forward (and stalling) or burning the clutch which are not good either. There is a triple sweet-spot (handbrake, clutch, throttle) which is easier to find when a given pedal movement translates into a smaller throttle change. SC increases this change hence makes fine-tuning harder. I hope this makes sense.
Parking brake is the tool to use.
1 - Pull brake up while pressing with your thumb the release button.
2 - Lift the clutch pedal to the engagement point while feathering the throttle to 1000/1200RPM.
3 - Lower the parking brake while accelerating and lifting the clutch pedal fully.
It works in San Francisco's Jones St. - it will work anywhere.
Whatever works. If it didn't work without SC, that only meant that you needed more throttle which is also achievable by pressing the pedal deeper.
I think I’m just not used to the 997 clutch yet. Got it in Feb, and haven’t driven it much. Had Boxster for 17 yrs and the clutch wouldn’t bite until close to top of travel. With my 997, it bites almost within 2 inches of release, so I feel like I don’t have enough time to give it enough throttle.
Carreralicious (07-14-2019)
I wondered about that the other day...I have a 997.2 and had noticed that I wasn't rolling back like I expected even when I wasn't doing a very good job. Thought something like "well that's really interesting...I guess that's an intentional feature of some kind?" Sounds like that's confirmed. Unfortunately I have nothing to add to the tips others gave for the 997.1...
Absolutely no idea. All I can say is that when I'm in first on a hill, when I move my foot from the brake to the accelerator I don't roll back like I feel like I should. It's like I'm still pressing the brake. I haven't tried that for any length of time, but it's definitely noticeable. I haven't even tried using the handbrake to deal with hills, mainly because I've never had to on any of my previous manual cars...but all those cars were much less high performance and thus less touchy about getting into first. I should note that when in neutral I do roll back as expected...which is nice, because sometimes I intentionally roll back just a hair as someone is coming up to me in order to signal "hey, I'm in a manual, maybe don't park right on my bumper" which probably doesn't work as I would like because people who would park on your bumper don't recognize what that means anyway.
Aside from proper parking brake technique and staying out of sport mode, there's a switch on the clutch that actually retards timing as the clutch pedal is being released to help people who can't drive sticks from either burning up their clutches or stalling their cars. It's a simple button switch and has nothing to do with the "depress clutch pedal" message and not being able to start the car without the clutch depressed - that's a different switch higher up.
Contort yourself under the dash and remove that switch from the clutch pedal - takes a 90 degree twist then pull out. Do an experiment where you either jumper the two wires together or tape the switch with the button in and drive the car doing normal shifting and trying to start on hills. Bypassing this switch makes the clutch to throttle relationship much more direct without it screwing with the way the engine is running when the clutch is being released.
I've had those 2 wires jumpers in my car for about 5 years now - just drives so much better.
Unfortunately .2 owners can't do this upgrade for regular driving (they don't need it for hills), as it throws a code in those cars.
