997.1 Window Regulator Replacment Help
6th Gear
Greetings Fellow 997'ers. My regulator has flown the coupe in my 997 S Cab. I've found sufficient instructions on the interweb for removing the door panel - and I've done that with ease. I'm now staring at the door panel and I'm not sure which way to go. I can't find a good set of instructions (Pelican's instructions kind of just gloss over the regulator removal part..). I'm afraid to just start removing screws - would prefer to follow the path somebody else has already blazed. I did search this forum and still didn't find a good set for removal of the regulator and reinstallation.
Any help and/or links much appreciated friends!
6th Gear
Self correction here - I did find deeper in the instructions better details about how to proceed on the Pelican instructions. Thanks anyway if any of you have further advice.
