Cleaning inside of headlight lens?
Hi all,
Long time lurker, new 997 owner- have a new (to me) 997, and love everything about the car. I have a question about what appears to be light hazing/fogging on the inside of the headlight lens?
When I pour water on the outside of the headlight assembly, there's no change, so I believe it's on the inside of the lens.
I have wetsanded and polished the outside of many lenses on my BMWs, but never the inside. I did a quick search and didn't fiind too much. Is there a quick and easy way to clean this, or does this entail putting the assemblies in the oven, taking the units apart and cleaning from the inside?
Any suggestions? A number of cars I looked at while shopping seemed to have the issue, so hoping for some suggestions from those that have a fix? Thanks!
I think for that, you’d have to bake and take it apart to get inside the lense.
I recall a thread where alcohol or some other liquid was put into the housing through the bulb opening, swished around and then removed. Worked well if I remember right.
Yeah that ^^^^^^ I was under the impression that the hazing on mine was an illusion caused by the tinted acrylic that was sprayed on them and that the hazing was a result of the light through the acrylic. If it is not and a simple liquid can fix it, lets do it..... so???????
DO NOT PUT ALCOHOL INSIDE THE LENS. There was a rumor this worked. It doesn't. And if it touches the silver coated plastic it will eat the finish off. Ask me how I know...
I had the same thing. Polished the outside and they looked great but when the lights were on they looked to have a light haze. In my case there wasn't anything inside the lens that was causing it. I think its either a) normal, b) the light diffracting differently after being polished, or c) heat damage that cant be polished out.
From whatever I've read and seen, do not even touch the insides of the lenses. It is generally only the outside that is subject to hazing and yellowing etc.
I would suggest polishing the outside surface first and then check for hazing.
Was curious last night, searched a bit and came upon this video....Was hoping someone would bring this up. I thought the video was about the product and I could easily find it, but no, it's about that model MB.... who cares about the car, it's that product we want, but there's no way to identify it..... unless someone here knows about it?????
There goes my hopes up again ...🙄
I'd much rather try this first, than bake open the lights and clean them that way. I have a whole complement of new bulbs for the light assemblies coming in- when they're here and time to swap, I'll polish the outsides first, and if the haze remains, move to cleaning the inside with the method shown in the MB video (will most likely use isopropyl alcohol and DIY microfiber cleaning kits).
I will try to take before, during, and after pics.
I attached a youtube video of a guy who disassembled a 997 headlight so he could paint the inside of the lens black. He thought it looked cool. Jury is out.
Anyway, he put it in the oven to soften the adhesive, then pried off the lens and meticulously cleaned the adhesive off. He reattached with butyl tape.
Seemed like a major pain in the ***. Im all for somebody trying and writing up their steps. However im betting you have a 10% chance of success.
https://rennlist.com/forums/997-foru...nt-inside.html
Thanks!
Here is the thread about cleaning the inside. It was our own Petza so maybe message him.
https://rennlist.com/forums/997-foru...ts-cloudy.html
