Difficulty putting 997.2 6spd into 1st gear sometimes
I'm sure this has been covered but it's too general a topic to search.
2010 C4S.6spd
Since purchasing the car last fall I have experienced this difficulty quite often.
I'd say 15-20% of the time when I go to engage 1st gear from neutral (stop sign or red light) it just won't go into the gear.
I have to quickly put it in 2nd then shift up to 1st.
Usually that works but sometimes even 2nd is tough to engage so I have to release the clutch and re-engage the clutch and then it always goes into gear.
The former owner said it happened to him all the time as well and was told it was normal.
Just wondering if anyone experiences the same thing and if a shifter adjustment is all I need or if it's more serious.
I've seen posts about adjusting the cables using a little plastic tool from the dealer?
The car has 84000 kms (52,000 miles) on it and has an OEM shifter that the dealer modified to be a short shifter.
When it works it's perfect and smooth.
Going into the dealer on Thursday and since I still have Porsche Extended Warranty I want them to look into it further.
Thanks!
2010 C4S.6spd
Thanks!
Common... it can be fixed quite easily. Demand only PTX... it is what is prescribed in your manual... not Delvac, what they mostly use.
https://rennlist.com/forums/997-foru...-gear-oil.html
Peace
Bruce in Philly
Peace
Bruce in Philly
As Bruce stated PTX can be purchased from Suncoast Porsche as they sell it in 1 liter bottles. You will need 3 of them. Really easy DIY. While you are doing that replace the drain plug with a magnetic one. The same drain plug is used for the oil pan so buy one of the magnetic LN engineering ones.
Common. Improved but not fixed with changing to PTX. Helped also with numeric shifter, new shift cables and motor mounts per some reports. Also better as the car warms up.
I would start with the PTX. Then go from there.
Good luck.
Good luck.
Basic Sponsor
A great video on it:
Available if you need it: https://www.suncoastparts.com/product/00004320420L.html
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow our Project 718 Build Thread!
Stay connected:
Join Our Newsletter
Facebook
SuncoastParts.com
Stay connected:
Join Our Newsletter
I had a simular issue and I centered the shifter and took the cables out of the connectors and reset them. That did the trick for me, look for instructions on shift console replacement for instruction. Also check your motor/trans mounts as worn mounts may impact shifting.
Just purchased the shift alignment tool from SunCoastParts. Will give this a try on Karen (06 997.1 C2S) and if she's still unhappy and asking to speak to a manager I'll do PTX.
I keep forgetting to update this post.
I ended up ordering from Sunset as they were less expensive AND would ship to Canada (Suncoast would not ship fluids).
Had my dealer do the swap as the car was in for some warranty work.
The difference is NIGHT AND DAY.
Holy moly.
The car shifts much nicer now and I've only had the gear jam about 2 or 3 times in TOTAL in the past month plus.
So glad for this recommendation.
Everyone should do the PTX swap.
Holy moly.
Holy moly.
Holy moly.
With this said, I only did the full synthetic fluids (no additives) in both the transmission and 4wd system and found things to be smoother too.
I read this thread yesterday and went "hey, I should find out if mine does that." I wouldn't have known, because my last car's first gear syncs went more or less completely out (when it was 15 years old and I'd been driving it like I stole it for 5 of them) and I had long ago developed the habit of just shifting into second as I came up to stop, then dropping it into first as I stopped, then pulling it into neutral. After that, first is completely available...hadn't even thought about it but I have been doing the same thing in the 911 this whole time.
Having now gone out with the express intention of seeing what happens if I don't do that...yep, it balks sometimes. Maybe 20% of the time or something. I guess I'll probably go ahead and put this fancy fluid in and see if that changes. But I'd also say that there are solid reasons to just do what I said above, even if the tranny isn't balking. You're just matching up all the spinny bits...even if your stuff is tip-top it will put less wear on it and keep it that way.
