Taillight Help
Passenger brake light failure issue.
Light bulb went out a few months ago so swapped it. Indicator came back up last week after the car has been sitting for a while so double checked. Brake light functions properly at first startup and no indicator. The moment I plug the driver seat belt into the receptical the passenger side brake light stops functioning and the indicator turns on for RR light failure.
I have no idea what's going on or how the receptical ties into the brake light. Anyone have this issue or now how to fix? Haven't had a chance to look at fuse yet.
This is a new one on me. Try disconnecting the battery for 10 minutes, which will reset the bulb control module. DON'T LATCH THE FRUNK OUT OF HABIT.
Don't worry about the new warning lights like PSM failure - when you reconnect it - they'll go away on the first drive after a couple seconds.
My 2009 .2 has a flaky plug/socket and half the lights will go out... pull it, shoot cleaner in there, reconnect and push real hard. Not sure is the cleaner has anything to do with making it work but what the heck.
Peace
Bruce in Philly
Peace
Bruce in Philly
