Rear Window Seal Bubbles 997.2
On our 2012 997.2, the rear window seal / gasket is bubbling or degrading in several locations. The bubbles are not sticky or goo-like. The front windshield gasket does not have such a problem. See attached photos for rear window seal / gasket degrading.
Our 997.2 is garaged and not subject to long periods in the sun. We hand wash, using the clear hot water three bucket method and microfiber towels, and use no soap on the exterior finish (the 997.2 does not get that dirty on the West Coast of Florida). If any dressing is put on the seal / gasket it is 303 Aerospace Protectant using a qtip.
There is a thread in the 991 Forum as to both the rear window and front windshield seal / gasket(s) actually deteriorating and turning into a black goo. The only 997.2 thread that I found addresses replacing the rear side window rubber gasket, which is riveted.
Has anyone else experienced this type of bubbling on the rear window seal gasket (I believe it is Porsche Part # 996-563-029-00, Back Glass Gasket)? I would guess that the rear glass is heat glued into place and the gasket seal is an appearance item; of course it could be glued in when the rear window is installed.
Upper rear window seal / gasket's bubbles.
Macro image of the rear window seal and bubbles.
Must the rear glass be removed to replace this gasket part, or is it similar to the 997.2 Targa, where the window gasket may to removed and replaced without removing the rear glass (another 997.2 thread)? Any experience with this issue, and what was done to replace the rear gasket / seal would be appreciated. Thanks, Type 2
Reset Rear Window Glass
The window removal and re-installation at our home took about two (2) hours, and it looks great! Repair installation cost on the Gulf Coast of Florida was $250. After he completed the installation we asked if he was married and if his wife liked red wine; we gave him a bottle of Insignia's second label Cab. He had also just restored a 2003 BMW 530, and in talking with us commented he could not find a coffee mug that would fit in the middle console of the 530. We had a new BMW closed coffee mug on the shelf in our inside storage, which we gave him with the bottle of wine. I don't believe we will have a problem getting him back to our garage if we have a future glass problem on one of the other Porsches. Pleased on the Gulf Coast.
Your back glass seal in its present wrinkled condition should not leak, because in addition to the backlite "rubber" seal, 997 545 901 00, there is a sealant placed around the perimeter of the back glass, which fully hardens and forms a seal inside of the backlite "rubber" seal. If you are steady and good with a razor blade, I firmly believe you could trim the failing 3/4 rubber seal at the top edge of the window glass (you have nothing to lose and if you do a nice job of trimming the athestics should be fine), and have no water problem.
ewc (02-18-2021)
Great info, thanks! I'm glad to hear that it's mostly a cosmetic issue. I don't think mine is as bad as yours was yet, so I'll see how things go and if the issue gets worse.
Type 2 here (OP). The surround window seal (actually a 3/4 seal, it does not go across the window bottom) started to disintegrate around the bubbles. I did research as to glass technicians, and found one across town who does excotics (McClaren and Ferrari) coupled with Porsches. Ordered the backlite seal, 997-545-901-00, and picked it up at the dealer ($104.00 with PCA discount). Stopped at the glass shop and arranged for the technician to come to my home to remove and replace the rear window (backlite) with a new seal. Monday's are best for most on-call glass installers as that day is not scheduled by most dealers for glass repair. We did not want to take the Black Edition to the glass shop, as it is best not to drive the car for 24 hours in order for the sealant to full dry.
Replacing that black gasket does not require removal of rear window. The gasket is just a cosmetic thing to cover the gap. You can pull that off by hand, remove any remaining residues and insert the new one in using a thing blade spatula. Have a spray bottle of clean water to aid that insertion of rubber into the gap. It is very easy to do. I did my BMW front windshield in less than an hour.
I was wrong about the gasket. It does require removal of rear window. Pretty involved and I would leave it to the pros if the bubbling issue bothers you. I looked up the workshop manual, not something I would want to tackle myself. Risk of breaking the rear glass would end up costly more than the money saved.
Type 2
ewc (04-27-2021)
Thanks OP for the information. I just noticed similar bubbling on the rear window gasket of my 2012 997.2.
Does anyone know if the replacement sealing backlite is made of a different material so this problem does not reoccur?
Does anyone have any glass tech recommendations in Orange County, CA?
