If that blowout happens to you out in the middle of nowhere in the cold and dark just consume the can of fix a flat and the misery will go away. I used a can of fix a flat on a motorcycle flat tire and that plus a flatbed solved the problem.
not sure really. Just driving and car began pulling and making awful suspension noise. Didn’t hear a blow out. Thinking something nicked the tire and then it just tore itself fully open driving a bit. Tried to convince the wife 4 new BBS wheels were required to fix this but she didn’t go for it.
Hilarious responses here by the way - thanks for the laugh all.
What is the tire's DOT code date? Is it the proper size (not "stretched ")??
2017 date code (got them on last summer and only have about 3k on them) and stock size on stock rim. Does look weird in terms of how it tore - basically right along a seam. Maybe a bad tire?
