ignition is loose...
hi, can someone tell me...do i need to remove the under dash panel to tighten the ignition switch(where the key inserts)
i have had it apart before but it has been a couple of years and i forget...the whole piece is loosened up and i'm thinking there is a set screw or some kind of screw that needs tightening
and just having had shoulder surgery i am kinda lamed up at the moment, and a little lazy..... could be the meds... tia, kk
