Replacement shock options?
Wifey needs at least 1 rear shock but wanting to do all corners. Bilstein PSS9s was what I was looking for but Tire Rack says takes months to get them. Bilstein has some sort of plant closure. C2S with 40k on the ODO, but maybe 30 autocross days often with 2 drivers each year since new. Any other options? Tire rack even has the OEM rears from Bilstein on back order.
Subscribed.
Ideally, replace them with Bilstein Damptronics and then add the TPC DSC module since it's an S with PASM - will do wonders for the track days and ride better on the street.
Seems like the Bilsteins are really tough to come by though these days.
The best option, but at a significantly higher cost, is TPC's own line of electronically adjustable dampeners which are the Tractive DDAs, but for a set of these and the DSC box, you're probably close to 5 figures.
