Car is stalling
Car is stalling
Put less than 1k miles on since purchase and having the following symptoms:
at 50k miles fuel filter, pump, plugs, coils, battery all replaced
now at 100k miles:
1) engine stalls randomly; happened several times
2) typically at 0-25mph, 1st or 2nd gear
3) fuel tank full and also when near 1/4 left
4) foot on accelerator and car stalls as if no gas
5) engine does not die. RPM drops and stays near 700
6) when I release accelrator and then re-engage, engine rpm picks up again and car speeds back up
Planning to inspect coils soon but has anyone experienced symptoms like this before? What could it be? Appreciate any insight. Thanks
now at 100k miles:
My benz did a similar thing and it turned out to be a bad / dirty plenum .
now at 100k miles:
now at 100k miles:
When you say it dies, it actually shuts off and you have to restart it or it bogs down and you can't make it accelerate, then it recovers?
If it's the latter, could be your brake pedal switch. Also, how long has that particular tank of fuel been in the car. If more than a few weeks, it could have become stale and you need to run it out and refill. If th car doesn't get Driven very often or very far, where the same gas might be In the tank for a few weeks at a time or longer, you should add Stabil 360 to every fill up.
I've had the symptoms like you describe occur two separate times in my silver car due to gas going stale and not since using the proper amount of Stabil in every tank.
As Pete said, is it stalling, bogging or surging?
If the latter, thats a fairly common issue when you have a bad gas cap seal. It typically happens a few minutes after the car started when trying to accelerate lightly. The car will buck and surge like you are about to run out of gas. Take your foot off the gas and it idles fine or mash the throttle and it clears up a bit.
If this is the case, here are some things that will typically clear it up:
1. First, pull over and unscrew the cap. Look at the condition of the seal and then screw back on to 3 clicks. That typically will clear it up if you just kinked it.
2. If the cap has never been replaced thats a cheap preventive measure. The seal gets old.
3. Lastly, fill the car up and reattach the seal.
Keep us posted.
Keep us posted.
Keep us posted.
Keep us posted.
