Cross post - would like advice on rubber window trim in TT section please
Some one in this section may have had the same issue. I have found a few threads regarding a "refresh" of the rubber, and also discovered that replacing it involves drilling out about 14 rivets to remove the window (which is not within my skill set
This was the most informative: https://rennlist.com/forums/997-foru...therstrip.html
It's more of a repair of a gash in the rubber that I would need to fix before respraying the trim with a rubber compound.
The thread is here:
https://rennlist.com/forums/997-turb...stripping.html
The thread is here:
